Old 03-07-2014, 07:50 PM   #1
1975 25' Tradewind
Cedar Park , Texas
Solar and Wind
Is there anyone out there who has used solar and wind power together to power their Airstream? If so, how many watts are you able to generate at the same time?
Bassistross is offline   Reply With Quote
Old 03-07-2014, 10:46 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Try eco-worthy.com... They have a wind generator and solar both running on a single controller.
Old 03-08-2014, 03:56 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
For trailer use, there are "toy" wind-power systems that will produce 1amp at 30vDC in a 20mph wind (but only 0.2amps and 12vDC in a 10mph wind from the same unit). The fan blades are about 15 inches in diameter, and they won't even turn unless there's at least an 8mph wind. Cost is only about $50 for something that size— cheap enough to experiment with in case you decide later it's not worth it; at least you wouldn't be out much money. But check the seller's return policy; no matter what model you buy, if it turns out not to be practical for you, it sure would be nice to return it for a refund!
Larger systems produce more power, but have larger blades, cost more, and are more complicated to set up because they have to be mounted higher for both safety and efficiency.
Oh, and small wind-power systems tend to be noisy. Those tall, elegant, silent offshore wind farms bear little resemblance to a small semi-portable model in that regard.
My personal opinion— which like all opinions is worth exactly 2˘— is that unless you LIKE camping in places where it's too windy to extend your awning, you'd be better served by going with a larger solar installation rather than trying to mix solar and wind power.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-25-2014, 01:56 PM   #4
2015 30' FB FC Bunk
Chevy chase , Maryland
I'm having my solar maxed out right from the git-go. I'll see where that lands me and report my findings. I thought it would be cool to get a nice turbine like I see on lots of sailboats. I might end up doing that just because I like the idea of 'givin' it to the man'. At home I have a 5kW solar array system that is more than enough to charge my fully electric Nissan Leaf. I dearly love flipping off gas stations as I drive by them at Mach 3.
Urfling is offline   Reply With Quote
Old 11-25-2014, 02:20 PM   #5
Colorado Springs , Colorado
Is it difficult to dismount a wind generator in the kind of wind you want it for??
minke is offline   Reply With Quote
Old 11-25-2014, 04:11 PM   #6
2011 23' Flying Cloud
Durango , Colorado
I have an AirX Marine wind turbine on my offshore sailing yacht. Although it will start producing at 10 mph wind speed, you really need winds of 20 mph to generate 100 watts. It is worthwhile on a cruising yacht in trade winds, but I couldn't imagine it ever being cost effective on a travel trailer unless you remain stationary in a very windy area. It requires a tall sturdy guyed mast, not something easily set up and taken down. The blades are sharp and dangerous. The rooftop solar installation on our Airstream is a much more efficient, quiet and trouble free solution for a travel trailer.
Safe Travels,
JamuJoe
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Old 11-29-2014, 09:15 PM   #7
2013 22' FB Sport
College Place , Washington
Your usage makes a big difference.... any high load usage? I go with the max it out school of thought, I have 450Watts that covers most anything in the summer. I go weeks without needing power and that including running the micro as needed.
Remember that flat roof solar panels are very inefficient during a large portion of the year. A few rainy days combined with shorter days and non optimum angles add up fast.
-Dwight
morgandc is offline   Reply With Quote
Clipper, Land Yacht, Electronics Dedicated Power Supply masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 19 08-01-2016 04:42 PM
27FB Solar Installation Report Start to Finish z8 hm Generators & Solar Power 52 05-06-2014 10:45 PM
RV Solar Kits - Good Prices... Mexray Generators & Solar Power 1 04-14-2014 07:46 PM
Solar Power for Battery Maintenance Tumajin Generators & Solar Power 10 08-12-2011 06:10 AM
