Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 01-22-2015, 08:18 PM   #1
2015 27' Flying Cloud
maple grove , Minnesota
Small solar to mount on LP tank or battery cover
Has anyone looked into mounting a very small solar on the lp cover or battery cover to trickle charge the battery when in storage
thebreezeman is offline   Reply With Quote
Old 01-22-2015, 11:14 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I have one which charges my dual automatic gate battery. Works great! I have had no issues with 'over charging'... If I recall, it is a 12 watt Solar panel.
Peace and Blessings..
Channing
WBCCI# 30676
Old 01-23-2015, 12:28 AM   #3
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
Your idea may seem simple but why not just go to the next step and instal a entire system on the roof with the new flexible solar panels and let the system work as is should? Your idea is a old way of looking at a problem that has a new solution.
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 01-23-2015, 06:59 AM   #4
Thanks but I believe your definition of the "problem" is different than mine. But thanks for the comment anyway.
Old 01-23-2015, 08:54 AM   #5
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Thumbs up
Yes, a 12 watt trickle charger that goes to our batteries. Mounted on the LP lid with no problems.
Had to look all over for a good photo, only one I could find on hand that shows it.
Heading over there tonight, so if you're curious about how it's mounted, I can take more photos.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 01-23-2015, 09:26 AM   #6
Vintage Kin
Fort Worth , Texas
small solar to mount on lp tank or battery cover
Man, I'm liking that blue/green tow vehicle in the pic. Methane power?
Old 01-23-2015, 03:01 PM   #7
dznf0g's Avatar
2007 30' Classic
Oswego , Illinois
In northern climes I'd go 15 watts. With the sun angle, cloudy days, and shorter days in spring and fall, I found, with 15 watts (after wiring losses, etc) and parisitic drains with disconnect switch OFF, that I got about 750mA output to the batteries in FULL sunlight. That's enough to make up for the above climatic issues. If I have 3 fully overcast days in a row, it takes one full sunshine day to return to 100% charge with a 15 watter. All this from observing the Trimetric monitor.
-Rich-
Old 01-23-2015, 05:28 PM   #8
Hey bold adventurer, would like to see more pictures
Old 01-23-2015, 06:04 PM   #9
Nomadic , USA
Thumbs up
Boom! Excuse the pollen. Florida.
ID:	230973   Click image for larger version
Old 01-25-2015, 01:28 PM   #10
1965 17' Caravel
Silver Cliff , Colorado
Solar charge.
I have done it and it works great on my 65 Caravel. Just make sure the polarity is correct. I quickly hooked a solar charger to my 64 Tradewind and the polarity was reversed, it ruined my battery and shorted out my 12 Volt side of the Trailer, now I have to replace the battery and find what all is not working. Be careful and don't hurry as I did.
Don
D Bishop is offline   Reply With Quote
Old 01-25-2015, 01:29 PM   #11
1965 17' Caravel
Also it is good to check if the solar panel has over charge protection.
Old 02-23-2015, 07:26 PM   #12
Nomadic , USA
After some research and removing mine, I believe now that it is a Sunforce 5W trickle charger based on a sticker on the bottom of it. http://www.amazon.com/gp/product/B00...KAMYV5P3XJPEZV
Stud Mount TV Mount on Shower Wall??? BASE729 Audio, Video & TV 7 01-30-2024 08:42 PM
External refrigerator cover and lid for battery cover needed for 1961 Ambassador 28' Ness Airstream Classifieds 0 01-02-2015 10:06 AM
credenza, dining table, small table for top of credenza, small table from other side of trailer janeinthemtns Airstream Classifieds 1 09-25-2014 05:24 PM
Roof mount Brackets for Solar Panel Bo2020 Generators & Solar Power 2 04-11-2011 01:20 PM
Flush Mount or Surface Mount Zac&Kristin Water Heaters, Filters & Pumps 10 01-13-2008 06:59 PM
