Old 10-04-2015, 07:09 PM   #15
Dwight's Avatar
1999 34' Excella
Joshua , Texas
I agree Lew. My system is about 10 years old.....I tried Blue Sky and didn't like the performance....then I tried the other and liked it.
Anyone can do a simple Google search on "blue sky or morning star mppt" and read all the threads out there. I'm not going to requote what anyone can read. I think folks should do there own fact finding and choose from what they want or can afford.
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 10-04-2015, 07:13 PM   #16
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I had a string of disappointing Blue Sky failures.... Jumped ship after being stranded.
Been using morningstar for a while with 0 issues or failures. Much happier with performance and zero failures!
Old 10-05-2015, 09:57 AM   #17
2013 22' FB Sport
College Place , Washington
At this point I have the controller, and am looking for understanding so in the future I can appropriately size both panels and controllers.
-Dwight
morgandc is offline   Reply With Quote
Old 10-05-2015, 09:45 PM   #18
2013 22' FB Sport
Lew, did you find that spec?
Old 10-05-2015, 10:38 PM   #19
lewster's Avatar
Naples, FL , Hood River, OR
The manual says a maximum of 340 watts of 36 cell panels at STC. IIRC, you have 32 cell panels (AM Solar's GS-100) and their recommendation is 400 watts max. I have used 480 watts (3-GO-160 watt panels) into the 2512iX-HV with no issues.
The manual also states that you should calculate a derating factor of 1.25 for NOC (normal operating conditions) which would bring a 425 watt array right to the recommended 340 watts.
Also remember that while Blue Sky doesn't like over capacity at the input of the controllers, they WILL accept it and simply clip the output amperage to the batteries at 25 amps. A typical solar array will only be producing maximum output for a short period as the sun's azimuth changes with regard to the panels' surface........... unless you employ an automatic solar tracking device that always points your array towards the sun at the optimum angle for maximum solar radiance.
Old 10-06-2015, 05:32 AM   #20
2013 22' FB Sport
Thanks. Part of me says that I want to know what is max safe watts while "clipping", the other part of me says why....controllers are not expensive, size it right and use every ray of sun on a limited footprint install.
Thanks for the input as always, and I am still loving my crazy over done solar install. Nothing like being able to run my microwave off solar whenever I want. Now if my batteries would quit living forever so I can get some lithiums. Of course, at only 3 years on the AGM batteries I expect quite a few more years, and I am not looking forward to getting them out from under that dinette seat on my sport.
-Dwight
Old 10-07-2015, 03:32 PM   #21
lewster's Avatar
No worries. They sure were not easy to install, but they WILL come out!!
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Charge wire on 7-pin, what demands does AS need and how does this charge starcraft Batteries, Univolts, Converters & Inverters 10 04-20-2012 08:38 AM
Univolt replacement now or later, and does solar affect which charge controller? mlepisto Batteries, Univolts, Converters & Inverters 3 11-05-2009 07:16 PM
Full Charge - No Charge! Cracker Batteries, Univolts, Converters & Inverters 2 06-22-2007 02:04 PM
Morningstar - Prostar charge controller, outside installation wacnstac Generators & Solar Power 5 06-07-2007 02:53 PM
Electrial surge charge controller WayWard Wind 1997 - 2004 Bambi 0 05-05-2003 08:28 PM
