Old 05-21-2016, 11:06 AM   #1
2016 28' Flying Cloud
The Plains , Ohio
Silly question
If you owned both an EU2000i and an EU2000 companion but were only going to need one on a trip (probably won't need AC), which of the two would you bring?
whitegs is offline   Reply With Quote
Old 05-21-2016, 11:18 AM   #2
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I would hold an elaborate ritual and end it off with "eeny meeny miny moe"
Kidding - I have no idea
PharmGeek is offline   Reply With Quote
Old 05-21-2016, 11:21 AM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Probably the companion as it works with the 30 amp cord without an adapter.
2012 Dodge Durango Hemi/AWD
Wayne&Sam is online now   Reply With Quote
Old 05-21-2016, 11:57 AM   #4
The Plains , Ohio
I have an adapter that plugs into my 50 amp trailer connection and accepts a regular extension cord that i could plug into the genertor, saving me the trouble of wrestling the heavy 50 amp cord (and possibly having to store it away each time when we leave the campsite). The eenie, meenie, miney moe solution is probably the best answer, since either generator will accept the regular extension cord.
I know it was a silly question.
Old 05-21-2016, 03:21 PM   #5
Senior Member
sheriff1's Avatar
2014 30' Flying Cloud
Sparks , Nevada
Try running your microwave or anything else you might need to run before deciding. I just discovered my convection will run but not the microwave on one generator. I had previously believed only my AC would require both.
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
sheriff1 is offline   Reply With Quote
Old 05-21-2016, 03:25 PM   #6
GoWhereTowed's Avatar
texas , Texas
I don't know if the companion has the battery charging cords and capability the 2000i has.
If you are reading this, it means I have made it another day!!!
GoWhereTowed is offline   Reply With Quote
Old 05-22-2016, 06:30 AM   #7
2013 25' Flying Cloud
Middleton , Idaho
Similar to what GoWhereTowed said. When I've had to make the same decision in the past, I usually took the standard eu2000i since it had the ability to charge a battery directly if needed (never needed to do it though). But now, I will take the Companion since I recently converted it to propane that can run directly off the trailer's tanks (the standard model was left as gasoline only).
Trailbob is offline   Reply With Quote
Old 05-22-2016, 06:32 AM   #8
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Charging your batteries from the converter/charger takes liken 700 watts (maybe more?) you can cut off that breaker I think if you need for a small bit of time to run the microwave. Of course hot water and fridge would be running on gas..
God luck on your trip
Silly Question kamadeca General Interior Topics 3 01-28-2014 07:23 AM
Ask a silly question... thewolffman On The Road... 5 12-30-2013 12:30 AM
Gaucho? Silly newbie question egad Airstream History 4 05-18-2012 07:25 PM
quick silly question! EoinmcCabe Buyer Guidelines 5 02-05-2010 07:17 AM
silly ball height question. AV8 Hitches, Couplers & Balls 7 11-09-2003 05:32 PM
