Old 06-22-2008, 07:50 PM   #1
philippes's Avatar
1994 36' Classic 36
Cincinnati , Ohio
Silent generator on Airstream motorhome 36 1994
Hello,
I have a 1994 Classic MOHO with solar pannels. It is called Silent generators. When I read the user manual,it claims that it has a2Kwatts power and I can run continously appliances such as microwaves.
Is there a point that I do not get?
My coach battery is drained in 5 minutes...
My GM dealer tells me that the user manua must be wrong.
Thanks for your help.
Philip
philippes is offline   Reply With Quote
Old 06-22-2008, 09:53 PM   #2
Desert Fox
1985 31' Sovereign
Tucson , Arizona
hi Phil,
Your solar panel manual must have one to many zeros in its power output. IT must mean 500 watts,and not 5000. The solar panels would have to be 10 times bigger and you would need a tractor trailer to haul it around. 500 watts is per day of charging your batteries. So forget you microwave oven that will use at least 1000Watts and will kill your batteries in about30 minutes.
Regards from Russell in hot a sunny Tucson Az.
RUSSELL is offline   Reply With Quote
Old 06-22-2008, 10:17 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by philippes View Post
Hello,
Philip
Phil,
Solar panels dating from 1994 are probably no longer functioning as intended. I just replaced an older system on an AS in TX and the panels were actually brown with very little voltage coming from them in full sun. You might have the same problem.
Replacing them with modern, polycrystalline panels at 100 watts /panel will give you an idea of the power capacity the new stuff has. It also has a lot to do with your battery capacity, wiring gauge and the type of charge controller that you have.
Check out the systems that I install at Welcome to AM Solar - Your RV Solar Specialists since 1987. After much research, I found them to be at the top of the heap for quality, capacity, performance and customer service, that's why I decided to represent them.
If you are planning to park for extended periods off the grid and don't want to be bothered by the noise of a generator, you might want to seriously investigate upgrading your system.
Let me know if you have any questions:
Motorhome Generator cooperhawk Mechanics Corner - Engines, Transmission & More... 3 06-22-2008 10:05 PM
1994 Airstream Land Yacht maedeans Member Introductions 2 10-13-2007 10:55 AM
New owner of a 1994 27 ft classic motorhome Scrapile Member Introductions 3 06-06-2006 04:54 AM
1978 Argosy 24ft motorhome generator panel Tom Schmidt Argosy Motorhomes 0 02-22-2004 09:52 PM
