Old 10-06-2015, 07:37 AM   #1
bvcg1's Avatar
1971 23' Safari
San Antonio , Texas
Short of Normal Draining?
I've noticed that my charge controller is blinking every morning, indicating that the battery is charging, or in need of some charge, even though the controller light indicates a full charge the night before. Is it natural for an AGM battery to drain a bit at night, or is this an indication that I have a short, or does my controller consume enough from the battery each night that its consumption is what is causing the light to blink? The AC power is switched off and there are no DC circuits within the trailer (clock, timing, etc.) that that is not switched to OFF.
bvcg1 is offline   Reply With Quote
Old 10-06-2015, 08:06 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Considering that a solar panel doesn't charge at night, it is normal that there would be a slight drain overnight since you're using some electricity at night that isn't being replenished by the solar panel until the next morning.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-06-2015, 10:11 AM   #3
1974 Argosy 20
Kooskia , Idaho
It depends on the specific charge controller and how it is designed, and a little on how it is installed.
For example, my Blue Sky MPPT charge controller has a green light which comes on each morning when there is enough light to activate the panels, and then it blinks and flashes in some pattern depending on the need to charge. It goes off at night when it is dark.
So, I would say what you have is normal, but each charge controller is a bit different. I would not worry about it at any rate.
Old 10-06-2015, 01:33 PM   #4
bvcg1's Avatar
1971 23' Safari
San Antonio , Texas
Thanks to both!
Short -Short Ramp Lights - Interior & Exterior 0 09-12-2007 04:34 PM
Draining eddo Fresh Water Systems 4 09-21-2005 08:28 PM
Electric water heater element: Draining dilema rfield54 Water Heaters, Filters & Pumps 4 05-19-2005 10:07 PM
The Short, Short Trailer - Spamboree flamingo-kid1 On The Road... 2 04-14-2005 01:41 PM
Shakedown trip--holding tank draining quest. Kistler Our Community 6 12-01-2002 09:21 AM
