Old 06-24-2014, 07:27 AM   #1
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Shelter for Generator
What do you use for protecting your generator(s) from the weather- rain, etc.?
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 06-24-2014, 07:45 AM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I use an 8' long plastic folding table covered by a tarp to house both 2000s with enough air flow for exhaust and pretty good coverage from rain.
SteveSueMac is online now   Reply With Quote
Old 06-24-2014, 07:50 AM   #3
twobikes's Avatar
1997 25' Safari
Montgomery , Alabama
Mine rides in an Actionpacker box when riding in the SUV. While it is running, there is an empty Actionpacker conveniently at hand. If a sprinkle comes up, I just invert the Actionpacker over it as a rain hood. (Leave the exhaust port clear if you intend to run it a while longer by leaving one end at ground level and the other elevated. The dog one connector is under the "hood" and only needs a little encouragement to remain off the wet ground. Put a little weight on the "hood" if you expect a squall.
PAT & AL MEYER
TAC AL-26 WBCCI 2626
Montgomery, Alabama
follow the Two Bikes and an Airstream blog at http://airgo.blogspot.com
twobikes is offline   Reply With Quote
Old 06-24-2014, 08:40 AM   #4
2006 25' Safari
Images: 8
Great ideas. Of course I have neither a table or an action packer but I do have a tarp. You've got me thinking! I have a single generator so if I went with the table idea I could probably get one smaller.
Old 06-24-2014, 09:41 AM   #5
2006 25' Safari
Images: 8
Thought, what about leaving the generator in the truck, turning the generator exhaust toward the rear, using the truck bed cover, leaving the rear tailgate open?
Old 06-24-2014, 09:44 AM   #6
r carl's Avatar
Lin , Ne
Some here use a small cheap tent.
Old 06-24-2014, 09:52 AM   #7
2004 16' International CCD
Chicagoland , Illinois
I use this:
SuperGen Tent | SuperGen Products
Airrogant is offline   Reply With Quote
Old 06-24-2014, 09:53 AM   #8
dznf0g's Avatar
Oswego , Illinois
I use one of these...dual duty for beach protection as well. I like multi-task items...less to take along.
Sport-Brella XL
-Rich-
Old 06-24-2014, 10:45 AM   #9
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have been using two Honda 2000's for the last eight years. We initially had a small children's tent to shelter the generators in foul weather. We used it only once. I about got a hernia getting the generators in and out of the tent. I got rid of the tent. Ever since I have positioned the generators under the back edge of the Suburban or Duramax. Doing this has always provided sufficient weather protection.
Brian
SuEllyn & Brian McCabe
Old 06-24-2014, 10:48 AM   #10
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
I put my generators under the back of the truck with the tailgate down. If it's really going to rain hard I shut them down and put them in the truck bed under the bed cover.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 06-24-2014, 11:19 AM   #11
dznf0g's Avatar
Oswego , Illinois
Originally Posted by Airrogant View Post
Interesting.....they don't list dimensions. Would 2 eu200s fit under that model or would you need the larger one. Could you measure and post? Does it really reduce sound noticeably?
-Rich-
Old 06-24-2014, 12:19 PM   #12
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
From page 5 in the SuperGen Tent store for the covers under additional information for each model:
Large 18 lbs 31 x 31 x29
Small 14lbs 29 x 22 x26
Old 06-24-2014, 04:18 PM   #13
The SuperGen Tent doesn't reduce the sound coming from the exhaust side, but the decrease in volume levels on the other sides of the enclosure is pretty dramatic.
Here is what seems like a good independent review of the system:
RV.Net Open Roads Forum: Tech Issues: 3000W Chinese Gensets Info.
Old 06-24-2014, 06:38 PM   #14
2011 30' Flying Cloud
Arvada , Colorado
We have two Honda 2000's and we merely leave them out in the rain, which I understand they are designed to do. I keep the generator off the wet ground by using our leveler blocks.
Jack46 is offline   Reply With Quote
Airstream BOMB SHELTER? bunkerman Modifications 60 01-17-2011 07:09 PM
Painting an Airstream Shelter guy99 Winterizing, Storage, Carports & Covers 3 11-04-2007 02:00 PM
