03-16-2019, 09:00 AM
Kyle
Self Built 200W Portable Solar Kit
Morning All!!
Has anyone here built their own portable solar charging kit?
I'm thinking of a couple of Renogy 100W panels and an MPPT controller (maybe 40A for future permanent installation). Pretty sure you can get hinges, handles and locks off Amazon ( )
Any guidance?
Thanks in advance
Neil
03-16-2019, 01:52 PM
Spring
Oh yes, you can get all kinds of things on Amazon. Just don't be surprised if you find yourself ordering something directly from China occasionally. How technical are you planning to get with your portable system? Is there any solar tracking involved?
03-16-2019, 02:35 PM
Kyle
Starstream....
I don't plan on anything too elaborate, I'm not that smart!!!. I think I just want something functional so I can boondock a little. I've been thinking I'll probably go with a 20A MPPT and if I go permanent, I'll get another controller then.
Neil
03-16-2019, 03:11 PM
Oswego
Originally Posted by Hodgey
Morning All!!
Any guidance?
Thanks in advance
Neil
I built this one for my son's camper. Stowed on the camper and 100 watts available for charging while on the road. Removed for portable site use.
-Rich-
03-16-2019, 03:23 PM
Kyle
now that I like....
Would you care to share the equipment used please?
03-16-2019, 03:27 PM
Oswego
now that I like....
2 X 100 watt renogy panels. Stainless piano hinge and latches (amazon), 50 feet of 6gauge marine stranded duplex wire coiled inside. Trailer is hard wired with 6 gauge and a Morningstar 15 amp controller. Trailer connector yet to be fitted through front streetside wall. Mounting feet and various connectors from AM Solar.
-Rich-
03-16-2019, 04:38 PM
Kyle
Thank You!!!!
03-16-2019, 05:26 PM
Sneedville
, Tennessee
You will see commercially available portable devices with the charge controller mounted on the panels. It works much better mounted near as possible to the batteries.
03-16-2019, 06:05 PM
Breckenridge
I have a 100 watt Renogy panel with 25' of extension back to a Bogart controller and monitor. I hook it up directly to the battery each time we go out. I made adjustable legs out of 3/4" pvc for the panel. Very simple and I learned a lot about how solar works relative tommy needs. Works great. I'm getting ready to install every thing as a plug in system but this has worked well for many years.
03-17-2019, 03:18 AM
Sneedville
, Tennessee
That's the way I ultimately configured mine. It was a commercially available unit but wasn't charging the batteries. I started experimenting with the built in solar charger, starting with rewiring the panels and putting the charger near the batteries. Made an instant improvement. Finally, upgraded to Bogart charger and monitor. That was in our trailer. We are now in an AS Interstate Class B and I have Bogart equipment in this as well. Works great.
03-17-2019, 07:22 AM
Kyle
That's great to know...so the better installation is to have the controller as near as possible to the battery then?
03-17-2019, 07:40 AM
Oswego
Yes.
-Rich-
03-17-2019, 08:12 AM
Spring
There are many days we're certain our smarts are suspect. When shopping on Amazon, if it's not a Prime item, we've learned to check how long it's going to take an item to ship. Over a week & it's being shipped directly from overseas.
03-17-2019, 02:51 PM
astrocaver
1986 25' Sovereign
Denver
Solar panels
Bought two 100 watt panels, hinged them together, used window latches to hold closed, added handle,. My wife sewed a cordura bag for storage. I mounted the controller on the back of the panels and 25 feet of solar connecting cord with quick disconnects. I wish it had been 30'. I put pigtails on one battery with the quick disconnects that stick out of the battery door on the front of the trailer. I filed a rounded spot in the vent holes so I could close and lock the door. Mostly the panels travel flat on the floor in front. If I am not going to be using them they get stored in the truck. For adjustable legs I bought a camera tripod at the thrift store for $5. Couldn't buy materials for that. If it is windy I have a cord and a tent stake to prevent any blow overs. of course I have a cable lock for when I am gone.
03-17-2019, 05:32 PM
1967 17' Caravel
Oak Creek
Can I ask how you mount it to the tripod?
Thank you
03-17-2019, 09:29 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
03-17-2019, 11:17 PM
astrocaver
1986 25' Sovereign
Denver
I took the tripod apart and used 2 of the legs, one on each side of the frame to support it. You can then adjust the legs for the angle you need. The legs are mounted to the inside of the frame so that when the panels are folded they are inside of the package.
03-24-2019, 02:42 PM
2015 Interstate Grand Tour
Chapel Hill
, North Carolina
Have an interstate too. Where did you put the controller and run the wiring?
Thanks in advance
Ian
03-24-2019, 06:20 PM
Sneedville
, Tennessee
Thanks in advance
Ian
Mine is an older model and the battery is under the passenger seat. The controller is right there with the battery. I removed the tv antenna and used one of those holes. I fished the cables over to the front of the sliding door and ran the cables behind the trim piece of the door down to the floor and into the pedestal. The battery monitor is mounted in the back over the sink where the rest of the monitoring gear is located. This wiring was ran behind the overhead cabinets and then over to the same sliding door trim piece.
