Old 04-06-2008, 11:40 PM   #1
2008 27' Safari FB SE
denver , Colorado
safe to operate genset in the back of a pickup?
Hi folks - newbie question
We are planning to use twin honda 2000's in parallel to power our new 27'AS. We're getting one to start until it gets hot enough to need the AC.
We have a Toyota Tundra pickup w a topper on the bed. If we cable lock the genset to the bed and open the rear hatch on the topper is it safe to run the genset (two in the near future) in the bed of the truck without needing to move them around???
I'm thinking this will be more secure than letting sit out on the ground.
Advice welcomed! Thanks.
Hector & Brenda
The "Luna"tics
2008 Safari SE 27FB - "Luna"
2008 Toyota Tundra
hlopez is offline   Reply With Quote
Old 04-07-2008, 01:01 AM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, hlopez. First thought was: will the generators overheat while running in the bed with a top on it. Next: you will have to turn them in such a way as to not have anything close to the exhaust like plastic bed liners or other camping equipment. And finally: does the topper have window access to the cab of your truck? You could get exhaust fumes in the cab. [Pets?]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-07-2008, 01:13 AM   #3
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Safe? Yes if the hot parts and exhaust don't melt surrounding stuff.
Prudent? Probably not as your truck bed and topper area will pretty quick smell like exhaust and that wonderfull smell may leak into the cab of your truck.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 04-07-2008, 02:15 AM   #4
_
sure, with the back lid open and/or the tail gait open the genset can operate from the truck bed.
others here do that.
i probably wouldn't, at least initially.
IF your main concern is theft, use a cable or chain and lock the genset on the ground to the trailer tongue or a wheel.
some folks attach a metal plate to the bottom and secure that with chain.
the genset will still need fueling, and spilling gas outside is preferred to IN the truck bed.
there is a risk of fire and fumes inside the truck bed,
and IF the truck bed is open EVERYTHING else in the bed is exposed to theft too.
also IF you wanna drive the truck anywhere the genset will need to be disconnected, stowed, secured and so on.
i keep the genset in a relatively sealed rubbermaid container, until needed.
placed on the ground for running, it's easy to service, fill with gas and ventilate on all sides.
i never leave it running unattended so theft is less likely, with me there and a cable lock.
it's covered with a rubber tub when not in use, to protect from rain or random eyes...
and IF i'm gonna leave and the camping area is suspect, back in the truck bed it goes...
that is one of the values of the 2k hondas, at ~45 lbs, they are easy to lift and move around.
IF using a larger genset (4000w models) which are heavy and hard to move, mounting inside the truck bed is a good option.
cheers
2air'
Old 04-07-2008, 04:56 AM   #5
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
I run two Hondas. Problem for us is that I always want to run an errand with the truck while DW doesn't. Keeping generators in truck just not practical. Also, they are two noisy to lock to the trailer tongue. Too close. Fumes to near as well. So, I set them out aways, lock them with cable, and secure a screeching motion alarm in place.
Sometimes at night I'll move them back next to the AS.
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
henw is offline   Reply With Quote
Old 04-07-2008, 07:27 AM   #6
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Can it be done? Yes. Would I do it? No.
If you strap your generator near the tongue, you could also get an LP conversion for it/them, and run off the LP that's on the front of the trailer, without having to schlep gasoline around. LP is clean, clean-burning, and can be had at most campgrounds. Noise would not be much of an issue, as if you are running loads heavy enough for the generator to be loud, you'll probably have the windows shut and the air on anyway, so you won't be able to hear it.
BTW, the 2000's weigh closer to 60 pounds, than 45, but they are still manageable.
Old 04-07-2008, 08:18 AM   #7
Pop Rivet's Avatar
1990 25' Airstream 250
Altoona , Georgia
I agree with overlander. They are also considerably quieter on the ground.
Pop Rivet is offline   Reply With Quote
Old 04-07-2008, 01:10 PM   #8
_
... the 2000's weigh closer to 60 pounds, than 45, but they are still manageable.
i've not put them on a scale, but honda spec's them at 46.3 lbs dry.
add 1/2 quart oil and a gallon of gas for the wet weight.
another issue with truckbed positioning is distance to the 30 amp trailer connection.
unless the a/s in question has the 'gen prep' option, which adds a 2nd 30 amp connector at the front...
the genset (in truck bed) will be a long way from the streetside rear plug.
the factory supplied cord will reach but just barely. i use a short cord.
lastly the o.p. appears to be in colorado so they might want to consider
the high altitude carb modification for gasoline, before fiddling with lp conversion.
above 5,000 ft honda recommends the carb modifcation to reduce fuel and improve emissions and performance.
even with the carb modification, they suggest performance will drop 20% at 5000 ft and another 3-4% for each 1000 ft of elevation.
which means a '2000 will offer 1600 watts of peak power (not 2000) and only 1200-1300 watts of continuous power....
switching to lpgas will further reduce power output.
cheers
2air'
Old 04-07-2008, 02:16 PM   #9
HowieE's Avatar
Princeton , New Jersey
Images: 12
I recently saw a very good answer to your question. An individual had mounted a generator in the back of his pickup with full intent to have them running while he is on the road or parked. The secret was he installed 2 fantastic fans and Max Airs in the roof of the trucks cap. One installed to draw in and one installed to suck out. This allows him to close the rear of the cap which cuts off the noise if he is still attached and operate in the rain while driving or stopped.
Needless to say he has wired the generators through the truck and rear doors to support this arrangement.
Not sure if his had remote start or not but that would be the Cats if he did.
2004 Excursion 4x4
Old 04-07-2008, 02:38 PM   #10
1973 25' Tradewind
Romulus , New York
That is very resourceful. I don't want to sacrifice all that space, but that sounds better than pitching a tent to house the power makers.
jayray5 is offline   Reply With Quote
Old 11-23-2018, 11:06 AM   #11
Raminc's Avatar
Wasilla , Alaska
cheers
2air'
I found it interesting that you have a Rubbermaid container to keep your gennie in. Where did you find one that large? Is it able to enclose with a cover?
Man plans ... The Gods laugh
Raminc is offline   Reply With Quote
Old 11-23-2018, 11:21 AM   #12
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Old thread but...
I too use an AP
But the Honda runs it its own tent...😂👍
ID:	328409   Click image for larger version
Name:	PISECO LAKE CAMPING JULY 2008 140.jpg
ID:	328411   Click image for larger version
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 11-23-2018, 12:23 PM   #13
Mollysdad's Avatar
Would I run a generator in the bed of a pickup? Yes. Mine is too heavy to lift out. However, I have a tonneau not a cap, and if I had a cap, I'd buy one of the exhaust extensions available from e-bay or others so the exhaust would go outside. I'd also consider a 120v fan plugged into the generator to keep air moving in the topper.
Someone posted his topper modification recently and it was very nice. The exhaust exited out the back window, as I recall.
UPDATE: I found it. It's Moosetags camper shell. Nice.
http://www.airforums.com/forums/f448...up-175334.html
For the Hondas, someone makes a vent/exhaust that covers the air flow vent. That way, not only the exhaust goes out, but the hot air too. I called them about my Honda 3000, and they said it needs 2" above the generator to fit.
Old 11-23-2018, 12:54 PM   #14
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I have a solid clamshell cover instead of a cap. I sometimes run the Honda 2000 sitting on the tailgate. I orient it so the exhaust blows away from the truck. I use a 10 foot 30 amp extension to be able to connect to the trailer. Yes, it is a little louder when operated that way. I think it is safe enough. When the truck is running there is a lot bigger exhaust pipe in that general area. Of course the bad thing about leaving the generators in the truck is that you can not leave the trailer for the day with the truck with the generator running to charge the batteries or run the AC.
I bought 1 generator with the plans to add a second for the AC. I never bought the second unit. Where and the way we camp we seldom need the AC when not on shore power. I added an Easy Start and have run the AC on the one Honda for a while testing but not where we really needed it. When it is really hot we seek out campgrounds with power. I left Teddy Roosevelt National Park a couple of days early before I had the easy start and went to a commercial campground with power and maybe would have anyway.
Plug for Easy Start: Even if I already had or was going to buy the second generator I would still install the Easy Start. It just seems to make the AC start quieter and softer whatever power source is running it.
Help us learn to operate the solar system. ClayandPerry Generators & Solar Power 15 01-31-2008 11:37 PM
Dodge Pickup ----need feedback please--- pap Tow Vehicles 15 05-09-2007 01:11 AM
Laptop in Pickup Zeppelinium Computers, Internet & Satellite 22 04-29-2007 08:49 AM
Genset on extended tongue safe? JimGolden Brakes & Brake Controllers 28 11-09-2006 10:11 AM
GM hybrid pickup Silvertwinkie Our Community 9 07-25-2004 03:39 PM
