We are planning to use twin honda 2000's in parallel to power our new 27'AS. We're getting one to start until it gets hot enough to need the AC.
We have a Toyota Tundra pickup w a topper on the bed. If we cable lock the genset to the bed and open the rear hatch on the topper is it safe to run the genset (two in the near future) in the bed of the truck without needing to move them around???
I'm thinking this will be more secure than letting sit out on the ground.
Advice welcomed! Thanks.
Hector & Brenda
The "Luna"tics
2008 Safari SE 27FB - "Luna"
2008 Toyota Tundra
Hi, hlopez. First thought was: will the generators overheat while running in the bed with a top on it. Next: you will have to turn them in such a way as to not have anything close to the exhaust like plastic bed liners or other camping equipment. And finally: does the topper have window access to the cab of your truck? You could get exhaust fumes in the cab. [Pets?]
Safe? Yes if the hot parts and exhaust don't melt surrounding stuff.
Prudent? Probably not as your truck bed and topper area will pretty quick smell like exhaust and that wonderfull smell may leak into the cab of your truck.
I run two Hondas. Problem for us is that I always want to run an errand with the truck while DW doesn't. Keeping generators in truck just not practical. Also, they are two noisy to lock to the trailer tongue. Too close. Fumes to near as well. So, I set them out aways, lock them with cable, and secure a screeching motion alarm in place.
Sometimes at night I'll move them back next to the AS.
2007 28' Int CCD.
2008 F 250 6.4L Diesel.
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Can it be done? Yes. Would I do it? No.
If you strap your generator near the tongue, you could also get an LP conversion for it/them, and run off the LP that's on the front of the trailer, without having to schlep gasoline around. LP is clean, clean-burning, and can be had at most campgrounds. Noise would not be much of an issue, as if you are running loads heavy enough for the generator to be loud, you'll probably have the windows shut and the air on anyway, so you won't be able to hear it.
BTW, the 2000's weigh closer to 60 pounds, than 45, but they are still manageable.
Terry You repair things with tools. You fix things with a hammer.
AIR#2611
I recently saw a very good answer to your question. An individual had mounted a generator in the back of his pickup with full intent to have them running while he is on the road or parked. The secret was he installed 2 fantastic fans and Max Airs in the roof of the trucks cap. One installed to draw in and one installed to suck out. This allows him to close the rear of the cap which cuts off the noise if he is still attached and operate in the rain while driving or stopped.
Needless to say he has wired the generators through the truck and rear doors to support this arrangement.
Not sure if his had remote start or not but that would be the Cats if he did.
