Old 03-14-2010, 07:04 PM   #43
1994 30' Excella
Mississauga , Ontario
What I was thinking was that using the fuel cell to recharge batteries might be a better idea than the solar system because it works 24/7 and is much lighter than the solar array.
You would still need your generator to power your air conditioner.
Al
Al and Jean
TAC ON-3
Old 03-14-2010, 07:05 PM   #44
1994 30' Excella
Also not sure that the fuel cell is available in North America yet.
I am going to send them an e-mail to find out.
Al
Al and Jean
TAC ON-3
Old 03-14-2010, 08:01 PM   #45
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
Originally Posted by Boondocker View Post
IF the AM100 panels can be mounted outside the fantastic fans, then two can go behind and two in front of the AC.
Eventually, I would want a larger battery bank as well
I am also trying to work out where a larger battery bank might work.
Something I've seen mentioned here is mounting your panels on your truck. If you have a shell on the bed of your truck you could mount the panels up there. If not you could buy/build a bed rack and have a lot of square feet of panel up there. It would be easier to get to tilt and position the truck for optimal sun sucking when the trailer is in the shade.
You would lose your battery charging ability if using the truck, unless you put your expanded battery bank in the back of the truck, which might be a good thing for an overloaded trailer anyway.
newroswell is offline   Reply With Quote
Old 03-14-2010, 08:11 PM   #46
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
I'm not crazy about that option, but everything is on the table. BUT doing that would require a new heavy duty cable from the truck to the camper AND the increased air drag would present a perpetual MPG issue. Those are serious issues for me.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 03-15-2010, 07:56 PM   #47
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
Rodney my panels on the Tradewind work great. They are mounted like you want to mount yours. There is no wind resistence that I have noticed. You saw how I had them mounted at the balloon fiesta. I wouldn't bother with a MPPT contoller I'd go with a PWM controller. The MPPT is only cost effective on a large solar array. For the Limited I'm going to try the Xanrex C35 Solar controller . The panels are in the back so you can't see them very well in this picture but these are 130 watt panels , for a total of 260 watts.
arodriguez60 is offline   Reply With Quote
Old 03-15-2010, 08:10 PM   #48
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
What panels are they?
Rodney
and the
My Blog
Old 03-15-2010, 08:53 PM   #49
1969 25' Tradewind
1983 34' Limited
Images: 85
They are Sun 130 31 x 42. They cannot be used on a grid tye system but for an rv system they work great! The site I got them from is Solar Panels : Solar Panels Direct $0.98 per watt when buying two pallets
Old 03-16-2010, 04:08 PM   #50
snake's Avatar
1994 21' Sovereign
Tucson , Arizona
Here is a view of a 43 watt and 75 watt panel on the rear roof of my 21' Sovereign, the panels are about 21" wide and 26" and 47" long, there isn't a lot of extra room up there:
Name:	solar panels.JPG
snake is offline   Reply With Quote
Old 03-16-2010, 04:29 PM   #51
Chief Chili Cook
newroswell's Avatar
snake, how are those feet attached to the roof?
Old 03-16-2010, 08:23 PM   #52
snake's Avatar
1994 21' Sovereign
Tucson , Arizona
I didn't want to drill any holes in the roof skin, so I made some 2" diameter aluminum pads with 1/4-20 tapped holes and attached them with 3M 2216 epoxy.
Old 05-02-2011, 05:58 PM   #53
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Back to thinking solar again, the new 100W panels are looking good.
Maybe this system with a second panel? Thoughts?
Rodney
and the
My Blog
Old 05-05-2011, 11:31 AM   #54
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
Boondocker I just ordered a system from them this week. I expect to get it on Monday. They are great folks to work with and have a good rep here on the forum. This system I got (covered on another thread here on the Airforums) is a 100W panel and a 50 watt. I may add another 100W later, after I see how this meets my needs). I substituted the Sunsaver 15 for the HPV 22B as I wanted the remote control head, and the Sunsaver should be all the controller I will need with my setup. I hope to get it up an running over the next couple of weeks as time and camping trips (2 more this month) allow.
Here is the other thread with info about installating a system and my comments about what I am getting. My comments are late in the thread, however, early in the thread you can see the installation of a system sold by AM Solar.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
What do you guys think of this solar kit available at Costco? wacnstac Generators & Solar Power 14 01-16-2013 07:05 PM
Is this an OK solar panel for my trailer bmklawt Generators & Solar Power 2 02-16-2010 03:44 PM
Identify this Solar Panel? bdegroodt Generators & Solar Power 7 01-02-2010 10:36 AM
Airstream vrs. Go Power Solar Kit jglase Generators & Solar Power 0 09-13-2006 08:05 AM
Solar Panel gilmorris Generators & Solar Power 14 12-05-2005 05:33 PM
