Old 03-10-2010, 11:18 PM   #29
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
Gen dissaray,
My only concern with your calculations for days between charging is that I have been told to try to never discharge a conventional battery below 70% for good overall battery life. I think you were using 50%.
wingfoot321 is offline   Reply With Quote
Old 03-11-2010, 09:06 AM   #30
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
nice collection of information
Here's a good link on mppt chargers
and one on battery cycles vs life, based upon flooded batteries.
The latter article does a fine job explaining the impact of frequent deep discharges, or regularly only drawing down the batteries 5 percent. Happy medium is apparently between 10 and 50 percent, and occasional discharge to 80 percent is not problematic.
Chasing 75 Degrees,
Jim N5RTG
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Old 03-11-2010, 09:49 AM   #31
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
After being nudged some to look at AM solar and being told the AM100 panel should be able to be mounted lateral to the fantastic fan, I am giving them consideration. I especially like that the panels don't have to be bolted on!
Option I
: The RV solar set up I was looking at was 2 panels (85 + 55 watt) for a total of 140 watts. Cost $900. Downside, the gopower GPR 25controller may not be as great as the vendor claims.
Option II. AM Solar 100 watt panel, Heliotrope controller HPV 22B $854
Option III. AM Solar 100 watt panel, HPV-30DR charge controler, HPV-30DR Solar Monitor. $1,184
Additional 100 watt panels for option II and III $468. (I have room for up to four)
I could see spending a bit more to get the controllers right upfront, but this would mean starting out with one panel and adding on later. How goofy would one panel look (remember this would be mounted lateral to the fantastic fan)?
A question for the electrical gurus: other than Option III allowing more panels, is there $300 of performance difference between the options?
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 03-12-2010, 08:28 PM   #32
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Is anyone using the HPV-30DR charge controller system that AM Solar is selling?
Rodney
and the
My Blog
Old 03-14-2010, 12:55 PM   #33
snake's Avatar
1994 21' Sovereign
Tucson , Arizona
My advice would be that if you have a limited budget, to put your money in the photovoltiac panels before buying a high end charge controller. This would particularly the case when you are using the system on a regular basis.
Although there may be a big difference in controllers, no controller can put more juice into the batteries then the panels put out. MPPT controllers may be more efficient under certain circumstances, such as very cold temperatures, but under normal conditions you'll get more bang for your buck with more panel capacity.
Controllers are just voltage regulators, some may be more precise, and have fancy readout displays, the real difference in performance would be when the unit is reducing the output when the batteries are at or a near to fully charged condition.
In fact, if your charging amperage is less then 10% of your batteries capacity you can wire it direct, with a diode to prevent a reverse current draw at night, without a controller without danger of damaging your batteries, the disadvantage would be increased evaporation of the batteries fluid when the batteries are in a fully charged condition.
snake is offline   Reply With Quote
Old 03-14-2010, 01:32 PM   #34
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
So are you saying that with my two 125 amp batteries (250 total) so long as the input from the panels is under 25 amps I don't even have to have a controller?
Rodney
and the
My Blog
Old 03-14-2010, 04:48 PM   #35
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
That AM Solar 100 seems a little high even at its current sale price of $379 ($3.79/per watt)? I'm sure it's a good unit though.
I'm looking at a Kyocera KD215GX-LPU on sale for $559 ($2.60/per watt). I haven't did my diligence on it yet, so I'm not recommending, just looking so far. Weighing in at 40 lbs, it's twice as heavy as the AM Solar 100, which is another thing to consider. It's good for 50/psf snow load, and 130mph winds!
newroswell is offline   Reply With Quote
Old 03-14-2010, 04:56 PM   #36
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Its 59x39 inches, I guess it could set sideways across the top. Other than that, I cant imagine where it would fit. It also appears to be for residential use, would it hold up to RV usage?
Rodney
and the
My Blog
Old 03-14-2010, 05:31 PM   #37
Chief Chili Cook
newroswell's Avatar
It's 18" wider but only 2" taller which works for me. Surviving the road is a real concern of mine as well. I need an 80 watt panel for a completely unrelated project and I hate to go buy one and miss a chance to upgrade what's on the stream.
Old 03-14-2010, 07:21 PM   #38
snake's Avatar
1994 21' Sovereign
Tucson , Arizona
I don't recommend it, but it could work without frying your batteries, you could skip the diodes and have an on-off switch to turn off at sunset to prevent reverse power drain.
Of course, a multistage charge controler with temperature compensation and all the bells and whistles would be best, and could be added at a later date.
It's hard to imagine that you have room for 400 watts on top of your Airstream, I've got a 75 watt and a 43 watt on my Sovereign 21' for a total of 118 watts, it could probably accomodate another 75-85 watt panel alongside the skylight and vent.
Old 03-14-2010, 07:41 PM   #39
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
That is definitely a concern I have. IF the AM100 panels can be mounted outside the fantastic fans, then two can go behind and two in front of the AC.
Eventually, I would want a larger battery bank as well
I am also trying to work out where a larger battery bank might work. Maybe street side under the bed, not sure there is enough space there without measuring though. And then, venting is an issue too.
Rodney
and the
My Blog
Old 03-14-2010, 07:51 PM   #40
1994 30' Excella
Mississauga , Ontario
Don't you think that mounting these panels from side to side on the curved roof is going to look a little bulky? And what about all that weight up there and the wind resistance when towing? And you travel a lot!!!(I'm really jealous about that).
All that expense and weight and you rely on a very bright sunny day each and every day.
I think that fuel cell I mentioned sounds better all the time.
And it is green technology as well.
Al
Al and Jean
TAC ON-3
Old 03-14-2010, 07:53 PM   #41
1994 30' Excella
Can't you use AGM's without offgassing issues? I'm not sure.
Lithium Ion batteries give large storage capacity with no offgassing but they are expensive. Oh and they are light weight for the capacity.
Al
Al and Jean
TAC ON-3
Old 03-14-2010, 07:59 PM   #42
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Al
I dont think I explained what I meant well. I was saying that I wanted to mount the panels along side (street and curb) of the vents. One set in front of the AC and one behind. The panels would be running lengthwise with the trailer body not cross way. I dont have any idea about the wind resistance but I think lots of people have four panels on the roof. I could be wrong, but that is my understanding.
I am going to let someone else work out the issues with fuel cells, I dont want a different generator which is what those seem to amount to.
Rodney
and the
My Blog
What do you guys think of this solar kit available at Costco? wacnstac Generators & Solar Power 14 01-16-2013 08:05 PM
Is this an OK solar panel for my trailer bmklawt Generators & Solar Power 2 02-16-2010 04:44 PM
Identify this Solar Panel? bdegroodt Generators & Solar Power 7 01-02-2010 11:36 AM
Airstream vrs. Go Power Solar Kit jglase Generators & Solar Power 0 09-13-2006 09:05 AM
Solar Panel gilmorris Generators & Solar Power 14 12-05-2005 06:33 PM
