Old 02-21-2016, 09:21 AM   #1
1968 28' Ambassador
Chicago , Illinois
Running airstream off solar generator
Hello, I am new to the forum and this is my first post. I have a 1968 ambassador that we parked on some land in the woods. It is our family getaway and we love it! There is no power or water so I have started converting it to an off the grid cabin/trailer. I have a wood stove and a self contained solar generator (a power hub) the generator works great to run string lights and radio etc.. I would like to plug the trailer into the generator to run just the trailer lights and ceiling fans. It worked for a while, but now the univolt buzzes and smokes. Seems like I need to replace the univolt. Any suggestions on what I need to replace and what to replace it with. I would like to avoid charging the airstream battery because it just drains the batteries in the generator. Please help, I have no idea what I'm doing!
Bchutto is offline   Reply With Quote
Old 02-21-2016, 09:30 AM   #2
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
How far away is the solar generator battery?
If it is close enough why not just run a heavy cable from that battery to the Airstream (AS), and remove the AS battery?
Yes, normally when they let the smoke out the device is severely stress and needs repair.
sgschwend is offline   Reply With Quote
Old 02-21-2016, 10:46 AM   #3
1968 28' Ambassador
Chicago , Illinois
The batteries fior the solar power and the generator are one self contained unit that I have in the space where the oven was. Are you saying you could run a cord from a new converter to the solar generator?
Old 02-21-2016, 09:07 PM   #4
sgschwend's Avatar
1986 25' Sovereign
Images: 13
I took a look at the Xantrex Power Hub 1800.
If that is what you have then I would say you would need a new charger and a 12VDC battery. I would recommend you go with a lower wattage charger (8-10 amps) and use the battery as a device to deliver your needed power. You are going through double conversion which means lower efficiency.
Since you already have a solution you won't want to go this route but here is a description anyway: Solar charger/controller, for a 12VDC system and use the house battery as storage. No need for a converter since you don't have power there. Lots of folks on this forum do this, some with really big systems use an inverter and create 120VAC to use.
Solar or generator or and generator? badkat Full-Timing 15 11-17-2014 09:59 PM
Running air conditioner off solar and batteries DavisBurns Sprinter and B-van Forum 29 07-17-2014 03:27 PM
Running Solar Wiring Mikec1231 Electrical - Systems, Generators, Batteries & Solar 0 07-05-2013 12:23 PM
Running generator on propane JDS Electrical - Systems, Generators, Batteries & Solar 11 07-27-2012 12:56 PM
AC water running off top of Airstream. acrane Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-01-2006 04:11 PM
