Old 04-11-2011, 12:01 PM   #1
New York , New York
Roof mount Brackets for Solar Panel
I have a Kyocera 135w solar panel and would like to mount it to the roof of an 83 airstream. Does any body know where I can get brackets that will work on the curved roof?
Is the best option to custom make aluminum solar brackets for airstreams?
Bo2020 is offline   Reply With Quote
Old 04-11-2011, 12:08 PM   #2
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
AM Solar sells a bracket that has a peel & stick adhesive that is unbelievable! The brackets do not need to be curved as the radius of the AS over the short distance of a couple of inches the brackets require is minimal.
FLYNCLD is offline   Reply With Quote
Old 04-11-2011, 01:20 PM   #3
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I used door hinges for my brackets, Standard hinges on the top, 4 inch strap hinges on the bottom. You can the take the panel side of the lower hinges loose and swing the panel up to get at the electrical connections, or even polish under there if you want.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Drainage system roof vent is missing.. Luc_DK Roof 13 03-30-2011 05:28 AM
2 roof panel questions jsapp Roof 2 03-24-2011 11:45 AM
Combining Black and Gray Roof Vents for 1958 mello mike Roof Vents, Skylights & Fans 5 02-06-2011 12:50 PM
