Old 10-30-2018, 03:52 PM   #1
2019 22' Sport
Malibu , California
Replacing solar roof flex panel
How do I replaced this panel that is no longer delivering amps? What is the white caulk dealer used and can I just remove the screws, use razor blade on the caulking and place new one where old one was with new caulk?
ID:	326687   Click image for larger version
Garfish is offline   Reply With Quote
Old 10-30-2018, 04:48 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Howdy,
It seems like the flex panels are OK for a year or so...... then they lose their ability to generate power. I have removed about 40 of these and they are not only sealed at the outside edge, but have double stick tape along the edges below the panel and several strips of the stuff below the panel itself.
First, remove the caulking and then the screws holding down the panel. Then start to lift the panel from the short side...... you will eventually get it off.
I would suggest using a hard panel in its place, along with a Victron solar charge controller if you want this to last more than a year or so.
Good luck!
Old 10-30-2018, 05:18 PM   #3
2019 22' Sport
Malibu , California
Originally Posted by lewster View Post
Howdy,
Good luck!
Thanks. Remove the caulking by cutting as with a razor? Or a solvent to remove?
Old 10-30-2018, 07:00 PM   #4
2007 22' International CCD
I'd try using a plastic putty knife first, then clean off the remains with plastic razor blades. If the caulk is soft, this may work well.
rmkrum is online now   Reply With Quote
Old 10-30-2018, 07:51 PM   #5
2018 27' Globetrotter
Mooresville , North Carolina
This^^^^. I'm a new Airstream owner and was at the Alumalina rally this past week and they had a seminar on this and also suggested using only plastic or wood and nothing metal to protect the skin. They also suggested using WD-40 to help loosen the sealant up in this process. Wooden Tongue depressors were also suggested.
GOUSC is offline   Reply With Quote
Old 10-30-2018, 09:01 PM   #6
Wolfwhistle
Wolfwhistle's Avatar
2013 23' International
HILLIARD , Florida
Try using a heat gun ... carefully... it will soften the sealant / adhesive
WW
Home Remedy is a 2013 IS 23FB. Tow vehicle is now a 2018 F150
Wolfwhistle is offline   Reply With Quote
Old 10-30-2018, 09:09 PM   #7
2019 22' Sport
Malibu , California
Caulk
What is the caulk to use to put the new panel on?
Old 10-31-2018, 11:00 AM   #8
alfred , New York
lewster,
your statement: It seems like the flex panels are OK for a year or so...... then they lose their ability to generate power.
I put 3 100 flex panels on my '64 globetrotter. Is this a blanket wide product problem, or select panels.
thanks
diane
nevermoor is offline   Reply With Quote
Old 10-31-2018, 11:23 AM   #9
sbowman's Avatar
1972 31' Excella 500
Grapeview , Washington
Howdy,
Good luck!
Hello Lew,
After reading what you have said, I thought great, ours panels are domed. However our flex panels are coming up on 2 years w/no sign of failure. Spent some time researching life span of flex solar panels on line. Did not really find any one answer and or domed issues. What I did find from many was cleaning and and care of. Warranties for flex panels are less than hard faced panels.
So my question to you is why and what is going on w/these flex panels that you have replaced? Why are they going bad?
Your experience and opinion is greatly appreciated.
Best regards and safe travels
Scott & Liz
2017 Classic
2016 RAM 3500 6.7
sbowman is offline   Reply With Quote
Old 10-31-2018, 12:26 PM   #10
lewster's Avatar
Howdy,
Most of my experience is with the Go Power panels that are found on the Airstream Interstate. These degrade rapidly and unless maniacally cleaned at regular, short term intervals, are just about worthless. Couple this with the controller that Airstream has used for a decade (or more) and you get a product that effectively will simply not work well or not at all in a short order.
I have tried these soft panels from several manufacturers about 3-4 years ago and they all have been effectively worthless after a short duration on the roof.
My suggestion is ALWAYS hard panels; either permanently located on your roof or a portable unit (up to 200 watts) that always seems t keep giving you the solar power that you have paid for.
Please let me know if any of you have more questions.
Thanks!
Old 10-31-2018, 01:00 PM   #11
Racine , Wisconsin
Use scraper blade on multitool. Who’s going to see a couple of scratches on roof. Finish cleaning with carb cleaner. Saves hours.
Kilroy is offline   Reply With Quote
Old 10-31-2018, 05:19 PM   #12
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 71
Recommend considering the following semi-flexible solar panel that we use. We did not want the raised roof profile presented by the rigid solar panels.
Solbian high-power semi-flexible panels
Solara walk-on high-power semi-flexible panels
Not all flexible panels are created equal.
Have been thinking of an awning where the panels zip together...
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2017 Infiniti QX80 Limited
ProPride 3P/Prodigy P3
gklott is offline   Reply With Quote
Old 11-01-2018, 09:29 AM   #13
1959 24' Tradewind
Twin Falls , Idaho
Plastic Scrapers
I don't know if these Harbor Freight scrapers will help, but the guys on TheVAP recommend they're use on aluminum, so they may be handy.
https://www.harborfreight.com/4-piec...set-95832.html
Regards,
Tony
Trons4u is offline   Reply With Quote
Old 11-02-2018, 05:09 PM   #14
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
We started using Flex Panels 10 years ago on our Alto trailers and Airstream's 6 years ago. Once we knew that ducted air was coming we started testing them on Airstream's just because the flat panels are so unattractive on the more curved roof of the ducted air units. We install approximately 250 a year.
To date we have not had any failures that I know of and we have plenty of customers that have pretty substantial systems who keep an eye on them. In June I tested at 2012 which was our first one with flex panels against a 2012 with flat panels. The flat panels were 90 watts vs the 100 watt flex panels. The current output was very close to even.
I wonder with our northern location that the panels are not subject to the extreme heat they would get in southern locations in the summer time? Having said that though our Alto products are all over Texas Arizona and Florida. Most of those have 12 volt fridges so we would know if the panels had died.
I too do not care much for the Airstream charge controller, we have changed out several to other brands.
I hope this helps.
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
White Flex Seal on the Roof? wildhorses Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 07-17-2017 11:40 PM
100W Flex Solar panel, Controller & Display JayP Airstream Classifieds 0 07-04-2016 05:45 PM
New Flex Solar DIY Project RaymondFitz Generators & Solar Power 36 07-28-2015 10:50 PM
Replacing univolt with solar panel system-newbie needs help keithgregg Generators & Solar Power 14 06-21-2015 10:05 PM
Thoughts on replacing roof interior panel with Plexiglass Projecttinca Interior Restoration Forum 11 07-12-2013 10:55 PM
