Replacement for Solar Inverter Remote By WFCO
Hi All,
On my 2013 30' Classic, I have factory installed Solar Panel system. My "Inverter Remote by WFCO", has beginning to fall. This part has a Push Button switch w/LED, in the center which cuts On/Off the Inverter Circuit (blue outlets).
It is time to replace because we have not treated it gently over the years. Airstream has discontinued this exact part. I was sent a replacement part (512680-100), at $107, that has a different Data cord (much smaller), it's larger, and it's square, mine is round which if it did work I would have cut the Aluminum wall for it to fit.
I will talk with airstream today to see if they take this part back and if there are other solutions. When I purchased it, the dealer who ordered for me, based on Airstream recommendation made it very clear they would not take it back.
If anyone could help with a solution or who has been through this before, I would be very happy to hear from you. Thanks for any help.
Freedom Rider and Roadrunner
2013, 31 'Classic
2012, 2500 Ram Longhorn, Air Safe, Reese Hitch
