Old 11-11-2019, 07:39 AM   #1
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Renogy Solar Suitcase Problem & Solution
I like my Renogy 200 Watt Solar Suitcase, but there is a small design problem which I have had to deal with. There are four plastic blocks which are used to mount the legs of the suitcase. I have had three of them break. Renogy sent me replacements, but they broke too.
My fix was to replace the plastic block with a drilled and tapped aluminum block. The pictures show a new plastic block, a broken plastic block, a new aluminum block and the aluminum blocks installed. If anyone is interested in plans, feel free to PM me.
Name:	Plastic Block.jpg
ID:	356014   Click image for larger version
Name:	Broken Plastic.jpg
Name:	Al Block.jpg
ID:	356016   Click image for larger version
Name:	New Blocks Installed.jpg
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 11-11-2019, 09:34 AM   #2
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
Very nice fix. Too bad Renogy does not use different material for their mounting blocks.
thewarden is offline   Reply With Quote
Test of Renogy 100w Eclipse Suitcase w/Voyager Con blacklab Generators & Solar Power 13 07-26-2019 06:32 PM
Renogy 100 Watts 12 Volts Monocrystalline Foldable Solar Suitcase Panels jamienate Airstream Classifieds 0 07-01-2018 04:39 PM
Renogy, Am Solar, Grape Solar, Go Power what's the best or what are you running?why? ASTailgate Electrical - Systems, Generators, Batteries & Solar 28 06-15-2017 12:30 AM
Connecting Renogy Suitcase to Zamp connection on 2017 Flying Cloud D44 Electrical - Systems, Generators, Batteries & Solar 2 01-18-2017 12:43 PM
Renogy 100 watt suitcase AWCHIEF Generators & Solar Power 24 02-07-2016 09:25 AM
