Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 09-20-2010, 07:32 PM   #1
1974 27' Overlander
Placerville , California
Removing Onan Generator '74 Land Yacht
Hello friends sorry if this has been posted before but not able to find out anything on it. I have an old Onan Model TL-212 R in my 1974 Airstream and am looking for assistance on how to remove it. Has no spark and I am interested in seeing about getting it running. From what I can tell it has points and they may be bad. If someone has pulled on out sure would be nice to get some pointers.
ronsgto is offline   Reply With Quote
Old 08-20-2012, 12:33 AM   #2
texasbound's Avatar
Bothell , Washington
Hey ronsgto,
Did you ever get it removed? I'm in a similar situation with my 1974 31'.
-=TexasBound=-
1974 - 31' Airstream Sovereign Land Yacht "Dudley"
WBCCI # 7616
https://ismelltexas.wordpress.com
texasbound is offline   Reply With Quote
Old 08-20-2012, 09:35 AM   #3
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
Originally Posted by texasbound View Post
Hey ronsgto,
Do you guys have any pics of your set up?
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 08-20-2012, 11:10 PM   #4
texasbound's Avatar
I'll post some tomorrow. I did see that there is a large access cover inside one of the closets. That might be the only way to get it out. I'm not confident that this thing will ever run, so I think I'll pull it for my big trip...get rid of some weight, and increase some outside storage area.
Have you pulled one veggie?
-=TexasBound=-
WBCCI # 7616
Old 08-22-2012, 06:56 PM   #5
texasbound's Avatar
Well its out! pretty easy project actually.... there are 6 bolts underneath the cover in the closet. you also have to disconnect a gas and battery lines.
everything was actually really smooth sailing until a stripped the last screw on the sheet metal trim on the outside. One pound on the screwdriver into the screw did manage to get it out after I used some penetrating oil.
my plan is to enlarge the space covered inside (not the opening/original door) to house two honda whisper generators in here. of course I will have to run them outside but it's a perfect storage area.
look at that original yellow shag! ! ! !
-=TexasBound=-
WBCCI # 7616
Old 08-22-2012, 08:16 PM   #6
1973 31' Sovereign
2007 20' Safari SE
wow that was easy, I didn't pull one like yours but I'm looking to get an Onan 4.0 so I was wondering about the set up of yours in case that it was similar, but not really.
Just wondering what was wrong with your generator?
2 chronicles 7:14
Old 08-22-2012, 11:10 PM   #7
texasbound's Avatar
For me it was an 80lbs anchor. Known problems with this generator drum the start, and it isn't even an inverter (age )... The space will fit one if my Honda whispers... Or whatever I get.
-=TexasBound=-
WBCCI # 7616
Old 08-26-2012, 08:49 PM   #8
1974 27' Overlander
Sorry took so long to get back to you but yes I did get it out you just have to remove the screws around the housing and remove wires. I have decided not to do anymore with this generator/battery charger dont think its worth putting money into it.
Old 08-26-2012, 09:29 PM   #9
texasbound's Avatar
Agreed! Mine is out and I sold it. Going with either two honda 2000's or one larger unit that I will keep in the bed of my truck.
-=TexasBound=-
WBCCI # 7616
Old 08-26-2012, 10:52 PM   #10
Uzzah's Avatar
1976 31' Sovereign
And you got a chance to relive the gold carpet!
Did you want fries with that?
Uzzah is offline   Reply With Quote
Old 08-27-2012, 03:05 PM   #11
texasbound's Avatar
So far, that is the only place I have found it!! Pretty sweet. :-)
-=TexasBound=-
WBCCI # 7616
