Old 08-03-2007, 08:26 AM   #15
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Originally Posted by MrAgent007
Thanks for your information.
Heck the generator is not the real problem; I suspect the stiff suspension on the Hummer may just shake the trailer apart. Again do a search on posts by Andy from Inland RV and he explains what an excessively stiff TV suspension can do to a trailer.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 08-03-2007, 11:45 AM   #16
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
It ain't the static loads...
Alex-
As the owner of short stout Airstream with receiver hitch mounted to very solid frame rails by Prior Owner, I've been through same dialogues..
We did risk it all by adding bike rack and bicycle on trip to Salem last summer.. We've now switched to folding Dahon Espresso bike that can fit inside or on top of tow vehicle...
The static load is minor, as you noted, and you could park a generator on the platform for storage purposes, or even when camped.. The problem is that the moment arm and mass of a generator creates a strong bending moment dynamically when the rear of the trailer is bouncing over potholes, drainage channels, pavement joints, etc.. Many of the most notable failures occurred with 1970's models when Airstream owned by Beatrice and cost reduction efforts reduced margins for a number of rear bath jmodels with heavy tanks under rear bumpers... Still a design issue, however... Airstream not identical to aircraft monocoque, since bottom is open and attached to flat wood floor attached to frame, but any stressed skin/shell design is marginally able to handle impact of incremental weight levered out from CG in vibratory motion..
There are threads offering examples and pictures of mounts for spare tire under A frame at front, and for mount of generator on top of A frame behind propane tank(s), even if some mod welding is needed. These might load up rear of tow vehicle and tongue weight, but put less potentially harmful stress on trailer..
Condoluminum
Condoluminum is offline   Reply With Quote
Old 08-03-2007, 08:46 PM   #17
MrAgent007's Avatar
2006 22' International CCD
Hershey , Pennsylvania
Images: 21
Thanks!
Hello, thanks for your information!
Alex
MrAgent007 is offline   Reply With Quote
Moving the Rear Bath Forward? jabra General Interior Topics 6 07-05-2016 10:52 AM
Hitch Setup Jabba Hitches, Couplers & Balls 2 10-04-2002 10:33 AM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 08:31 AM
Trailer Friendly Camping California bkpine Our Community 31 08-19-2002 01:26 PM
New trailer, old club rally Pahaska Other Rallies & Events 7 07-24-2002 01:26 PM
