Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 02-17-2003, 05:28 PM   #1
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Propane Powered EU2000i?
Check out this link for a kit to convert your EU2000i to propane. The kit makes the generator run on propane ONLY after the modification. There is not enough room in the EU2000's case to make it multifuel. Kind of neat, it may be easier and safer to carry an extra 20# propane tank than a can of gas. One thing that would concern me is that I think the generator would be derated by 5-10% running on propane.
EU2000 Propane Conversion Kits
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 02-17-2003, 05:47 PM   #2
John
Profile:
Pick,
It would be cool if you could mount it on the A-frame and tap into your 30# tanks!
But then if you gain some altitude, you'll lose even more power .
John
John is offline   Reply With Quote
Old 02-17-2003, 07:36 PM   #3
femuse
Profile:
Thanks for the link. I just checked it. We have the EU3000i and they have the kit for this one too (not for the 1000 unfortunally).
Chantal
femuse is offline   Reply With Quote
Old 02-17-2003, 09:24 PM   #4
RoadKingMoe
RoadKingMoe's Avatar
Profile:  2001 34' Limited
Beavercreek , Ohio
Hmmm... rather than carry a coupla 5 gallon cans of gas in the truck bed, that would be a coupla spare 20 lb (5 gallon) bottles of propane in the bed, or for me, one spare 40lb bottle. Probably need two 30 lb bottles from what I hear about propane generators.
Maurice
AB8XA
WBCCI 5446
The Long, LONG Trailer
Old 02-18-2003, 08:48 AM   #5
Pick
Pick's Avatar
Images: 36
My Calculations....
Well, I think they are stretching it a bit, when they say that a propane powered generator will run "about the same time on a gallon of propane as gasoline". First, they assume 92,000 BTU per gallon. Actual is close to 91,504. Gasoline is roughly 116,000 BTU per gallon. With the figures stated on their webpage, (link below) I come up with the following figures:
Honda EU2000i Running full output 1600 watts:
Propane Consumption: 2.85 Hours per Gallon of Propane
Gasoline Consumption: 3.625 Hours per Gallon of Gasoline
Or, roughly 27% more fuel consumption!
Other factors to consider, are that, according to their specs, a 20# propane cylinder may not run an EU2000i at full power, a 30, or 40# may be required, especially in cold weather.
Pros: Safer cleaner refueling, no worry about spilled fuel. Longer engine life and easier starting. You are more likely to find a campground selling propane than gasoline. MIGHT be somewhat of a theft deterent. Run time is limited to how big your propane tank is, built in gasoline tank is 1.1 gallons.
Only con at this point is cost of conversion and increased cost of operation. But for as much as I will use it in a year, that will be not much of an issue.
Propane Generator Fuel Consumption Information
Lots of Hot Sauce!
Air # 283
Old 01-22-2004, 04:02 PM   #6
Tin Hut
Tin Hut's Avatar
Profile:  2005 28' International CCD
Southlake , Texas
propane
Pick, great analysis. If you had a pickup I could picture a large bedded propane tank that could feed the generator. That would be a interesting setup. Hauling gas cans around always scares me so having a propane option would be nice.
"would you rather have a mansion full of money or a trailer full of love?"
Warning: (20%)
Tin Hut is offline   Reply With Quote
Old 01-22-2004, 04:09 PM   #7
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
I would not worry about a bed mounted tank. There are plenty of frame mounted tanks that are available and then the bed is left clear for other things. I was always amazed at the amount of wasted space between the sheet metal and the frame on the trucks I owned.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
New Propane Tanks... Sneakinup LP Gas, Piping, Tanks & Regulators 10 01-31-2004 06:15 PM
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 11:34 AM
Propane Usage COArgosy78 On The Road... 6 02-25-2003 10:35 PM
Leave Propane Bottle Valves Open? heyskipper LP Gas, Piping, Tanks & Regulators 3 02-23-2003 09:19 PM
Disposable Propane Bottle Safety JaceBeck Our Community 6 07-02-2002 02:15 PM
