Old 11-19-2003, 11:11 AM   #1
nevisstudio's Avatar
Images: 8
propane generators
im lookin into getting a propane generator to help while camping......
im not sure what to look for in terms of what kind of power outage would be sufficient....22' saffari...
any insight would be much appreciated...
thanks
rich
nevisstudio is offline   Reply With Quote
Old 11-19-2003, 11:54 AM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
You are going to need a bare minimun of 3500 watts 5000 would be better, unless you don't plan on any high draw items like microwaves, crock pots, or AC then if you were careful you could get by with 2000 watts. Why the LP powered and not gas?
Aaron
Old 11-19-2003, 11:57 AM   #3
87MH's Avatar
1978 31' Sovereign
Images: 292
Gasoline Instead of Propane
FWIW
It's been my experience that Propane and Natural Gas fueled recip engines are more difficult to start than Gasoline.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 11-19-2003, 12:08 PM   #4
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Onan 5500 Gold LP
I recently installed this unit in a trailer and I am convinced that this is the cats meow.
It started practically instantly, Utilized LP with very simple installation.
And the best part, you could literally stand within 2 feet of it and carry on a conversation without raising your voice.
I believe the sound rating was a quiet 67 decibels. The quietest unit I have seen to date. Did I mention that it powered a new Coleman AC? along with a full 15 amp load on a Furuno Radar system.
The cost is well worth the product. I intend to have one in my future MH.
Smily
smily is offline   Reply With Quote
Old 11-19-2003, 12:11 PM   #5
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
Here's some discussion on using propane for generators. Bottomline is that the same generator is less powerful and consumes more gallons of propane that it would gallons of gasoline. Carrying a 30 lb bottle of propane is probably equivalent to carrying a 5 gallon can of gas. Propane is also a lot more expensive per gallon than gas.
Maurice
Old 11-19-2003, 12:24 PM   #6
2001 34' Limited
The State of , Ohio
Ken... you put a Furuno radar on your AIRSTREAM? LOL! Afraid of a big rig backing into it in the fog? Does it do overlay with your GPS?
Maurice
Old 11-19-2003, 01:02 PM   #7
Onan 5500 Gold LP
Smily
Ken Smillie
WBCCI # 12499
Ken:
You say that you recently installed an Onan on a trailer.
I am very interested in this instillation.
Can you be more specific.
What trailer?
Where did you install it?
Pictures?
jim
Texas
jim
judge3rd is offline   Reply With Quote
Old 11-20-2003, 06:13 AM   #8
Still Working
smily's Avatar
1994 36' Classic 36
Trailers and Airstreams
Not only do I dabble with Airstreams but the government pays me to fabricate transport vehicles for their mobile communications systems. I was tasked with building an experimental radar system, "BASH" Bird Air Strike Hazard, that is intended for use at Airports. They set this unit on the tarmac and project it out towards the launch and landing path. They look for congregations of birds and or other objects that could cause damage or crashes to very expensive aircraft and personnel.
A photo of the BASH unit. Not an Airstream but I assure you the same care and quality that I expect in an Airstream.
Name:	twin to full photos 005.jpg
Old 11-20-2003, 06:17 AM   #9
Still Working
smily's Avatar
1994 36' Classic 36
Outfitted
See all the ammenities?
Automatic levelers, obstruction light, AC, both A/C and D/C electricity, grounding, radar unit........... and yes that is a GPS antenna on the rear of the trailer
Name:	twin to full photos 009.jpg
Old 11-20-2003, 07:09 AM   #10
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Whoa!! Ken that is ultra cool!!! That looks like a top notch installation.
The main advantage of propane in my opinion, is longer run time and availability of fuel, in a camping situation. Many have converted outboard motor gas tanks to work with their Hondas.
RoadKingMoes is right as rain, when he speaks of propane being more expensive, and certainly less power as propane is 91.500 BTU per gallon vs gasoline's 116,000 BTU per gallon.
I have often thought of converting my EU2000i to propane. But I am getting more use out of it around the farm, than I am camping. At this point, the portablity issue is more important to me than run time. During the "Big Blackout", I filled the tank at 11pm before retiring and it was still running, powering the house fridge at 6AM.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 11-20-2003, 07:30 AM   #11
Still Working
smily's Avatar
1994 36' Classic 36
Storage
My interest was storage of flammables.
Obviously, storing a gas can and transporting in my opinion is more risky that transporting LP in a sealed container.
Also, Airports typically have LP fueled ground equipment and the reason is the same, storage.
I felt that this setup was the best
Name:	twin to full photos 010.jpg
Old 11-20-2003, 08:12 AM   #12
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
propane genset in MH
My MH's owner's manual states that the 4.0 Onan runs off the MH gasoline tank. However, the PO told me that it's now a propane generator, and that he got it that way from the original owner. It has a large diaphram in front of it typical of propane conversion kits. Apparently he either converted it or replaced with a different one.
I was miffed that the genset was not gas at first, but as I used it on the road and off, I found it to be quite easily started, although sort of loud. It powered my microwave and tv. What I like about it is that it won't run down the gas tank if off road as a gas one would.
Astrodokk is offline   Reply With Quote
Old 11-20-2003, 11:24 AM   #13
2001 34' Limited
The State of , Ohio
Nice rig, Ken!
Maurice
Old 11-20-2003, 02:00 PM   #14
Images: 8
kind of confused.....
the fesibility of some of these genrators does not seem so efficient.....in terms of size.......with them being so large one would have to enclose one compartment just for the generator.....no....
what do others do for power where a power hook-up is not available.....
Propane Powered EU2000i? Pick Generators & Solar Power 8 04-09-2016 06:36 AM
Generators . . . again? dinoburb Generators & Solar Power 6 03-18-2008 07:36 PM
Propane tanks question Swingking LP Gas, Piping, Tanks & Regulators 8 10-22-2003 09:55 PM
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 10:34 AM
Propane Usage COArgosy78 On The Road... 6 02-25-2003 09:35 PM
