Old 11-21-2003, 09:03 PM   #29
Tinsel Loaf's Avatar
I will take a flick this weekend and post.
Tinsel Loaf is offline   Reply With Quote
Old 11-21-2003, 09:20 PM   #30
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
87MH, Amerigas just charged me $1.81 per gallon to fill the home tank. Local Flying J is at $1.34. Around "here" all of the local propane companies are big cheating, chiseling, ripoffs. Amerigas wants $23 to fill a 30 pounder, yet you can do it at Flying J for around $10.
The local Linde industrial gas dealer had some neat horizontal 40# tanks for around $150. They had a level gauge and big filler.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 02-28-2004, 11:59 PM   #31
2001 19' Bambi
Falmouth , Massachusetts
Propane EU3000
Three years ago I modified my EU3000 to run as dual fuel, primarily on gas but alternately on propane. Details of the conversion, including pictures, are on my site:
http://www.mswartz.com .
Also, on www.irv2.com I posted several articles on the process and results (search for user mswartz, listing all postings.)
I used a conversion system from Carbturbo.com, and since the installation, I've put over 600 hours on the genset (has an hourmeter) with about 200 of that on propane.
My experience is that the unit works well on propane, but in cold weather (ie, propane tanks below 30F) the genset can experience fuel starvation under load changes, and I therefore usually run the unit on gasoline when I expect the temperature to be below 40F.
In warm conditions though, propane operation has run the genset well, reliably allowing the 11kbtu Dometic airconditioner to cycle in its normal modes. I leave the economode switch ON at temperatures over 40F. and OFF below that.
Lately the price of propane has reached record levels here in SE Massachusetts, costing $20 to fill 30LB tanks last week. Certainly gas is more economical for the delivered BTU, and from the standpoint of operating efficiency for this genset works best.
When I'm on a remote site for awhile with the trailer, I can connect to bulk propane tanks and avoid the gas refills, however.
Marshall Swartz
2001 19-ft Bambi
2013 Honda Ridgeline RTL
mswartz is offline   Reply With Quote
Propane Powered EU2000i? Pick Generators & Solar Power 8 04-09-2016 06:36 AM
Generators . . . again? dinoburb Generators & Solar Power 6 03-18-2008 07:36 PM
Propane tanks question Swingking LP Gas, Piping, Tanks & Regulators 8 10-22-2003 09:55 PM
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 10:34 AM
Propane Usage COArgosy78 On The Road... 6 02-25-2003 09:35 PM
