Old 11-20-2003, 02:24 PM   #15
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
I use two quiet and light Honda EU2000 generators paralleled, sitting on the ground next to the trailer. One will handle everything except the air-conditioner.
Maurice
Old 11-20-2003, 02:40 PM   #16
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Airstream, actually all of the Motorhome manufacturers installed LP Gensets in the diesel coaches they built for quite a while due to application availability and the cost of the deisel gensets was STEEP. Now the big pushers all have diesel gensets and they are generally the size of a Big Block engine, slung between the front frame rails. They are quiet and liquid cooled, but on a $150K + coach you should have a single fuel source like diesel.
While not for everyone, the LP gensets offer some flexability for those who want or need one that is a fixed installation. I like my unleaded gasser, and would not consider changing my genset to LP.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 11-20-2003, 05:51 PM   #17
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
My preference would be the gasoline, because I can tote gasoline plus most MH have LARGE gas tanks, LP tanks are alot smaller and it is hard to refill a fixed LP tank I was reading a thread on a bus board a while back about the pro's and con's, most people felt that diesel (if you had a diesel bus) were the only way to go, that when you were boondocking for any period of time that people could not stay as long that were running the LP gensets as those running the diesel. Also FWIW LP tanks are heavy for their capacity! I like the set up that Smily has and it makes sense in that application
Aaron
Old 11-20-2003, 06:16 PM   #18
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Secret
I would show you the interior but that is sensitive stuff
Actually there is a Huge flat screen Monitor and a superfast PC with a webbrowser locked onto WWW.WBCCI.ORG
Come and check it out
smily is online now   Reply With Quote
Old 11-20-2003, 07:04 PM   #19
Tinsel Loaf's Avatar
I use a 4000 watt propane unit and like it alot.
It has a starter and starts easly, runs effortlessly and does not smell like gas fumes. It uses about half gallon of propane per hour which is enough to power our ac, charge the batteries & run the appliances.
Tinsel Loaf is offline   Reply With Quote
Old 11-20-2003, 07:54 PM   #20
Tinsel
Where do you have the generator and how is it placed?
jim Texas
jim
judge3rd is offline   Reply With Quote
Old 11-21-2003, 02:07 AM   #21
Smily, if you don't mind me asking, what was the cost for the Onan 5500? Everyone, what is the current price for propane down there? We are paying .35CDN/liter up here. I will need to dig up my conversion calculator for USD/US gallon. But I do know this is half what we pay for gasoline at .69CDN/liter, so a propane fired genset seems to be the ticket here . Just curious. Thx.
bbb
biggerbadbrad is offline   Reply With Quote
Old 11-21-2003, 02:22 AM   #22
...okay here goes...carry the 1...take away 6...equals...
$1.02 USD/ US gallon propane
$2.01 USD/ US gallon gasoline (regular unleaded)
Whew, I need to take a nap now!
bbb
Old 11-21-2003, 04:52 AM   #23
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
not very useful by todays standards...
airstream has had factory installed generators in the past, propane powered.
this is a photo of one, onan, about 900 watts 12 volt! mid '70's vintage.
would be useful for recharging batteries when boondocking and that is about all!
single cylinder, horizontal. looks like it was borrowed from a lawn mower!
it is mounted street side just behind the wheels.
cool control panel with remote start and run timer in living room.
john
you call them ferrets, i call them weasels.
Old 11-21-2003, 06:54 AM   #24
Atic Fox/Nash place the generator boxed inward, open to the outsided, in the bathroom area wardrobe or closet area. Accessable from the outside and vented outward.
They are not aluminum framed and have a heavier carriage.
However, properly supported and insulated an outward facing generator should be readily doable at the factory. In motorhomes, the smaller generators are either diesel or gas powered, same as the coach. The well placed ones are on wood, both for the sound deafening, then the enclosure is also sound insulated. LP is the logical solution in a TT.
In the meantime, as posted previously, the interium solution is
http://www.aurasystems.com/, especially for a diesel tow.
I have looked at the site completely, including the "white papers." There is no reason that you could not run all of the electrical demands from the tow vehicle with this set up, either gas or diesel (? idling in heat with gas engines) including 15 airconditioner and microwave, simultaneously, while watching the super bowl from the dish, holding a cool one, in a boondocking situation. The tow just idling and creating electrical power. Note that the AuarGen has a remote kill/start. Couple that with remote kill/start on the tow and you never have to leave the AS.
Until AS incorporates a generator, AuaraGen is where I am heading. No separate fuel issues either.
jim
Texas
jim
Old 11-21-2003, 09:46 AM   #25
2001 34' Limited
The State of , Ohio
If Airstream was careful about constructing a compartment, and locating it, where exhaust fumes couldn't seep into the trailer, they could certainly have Honda adapt an EU1000 for propane, with proper air cooling for a compartment, and perhaps even an electric starter. Of course, you'd want 40 lb propane bottles on a trailer so equipped.
The converter would have to be limited to about 40-45 amps because the 1000 would have to be derated to maybe 700W continuous, 800W peak, with the lower energy of propane.
Maurice
Old 11-21-2003, 10:47 AM   #26
87MH's Avatar
1978 31' Sovereign
Images: 292
Cost of Propane (LPG)
Finding the best place to purchase propane (actually LPG, true Propane hasn't been sold in years), is much more difficult than pulling into the "cheapest" gasoline station.
The cheapest I have found LPG this year is $1.25/gal., and last month I paid $2.00/gal. (Houston, Texas area.)
How does that compare to the rest of the country?
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 11-21-2003, 12:59 PM   #27
I have a 25 gallon manchester propane tank in a DOT approved dog house in the van. The setup uas insalled by a local propane company and ran about 2K. All the connectors are located on the outside of the van. I have a tommy lift on the van which I lower and roll the generator out of the van on the lift and close the doors. I plug a quick disconnect hose into the external propane connector and a quick connector on the generator.
I can start it on from the generator or from the inside of the AS. I plug the AS into the generator which charges the AS batteries and three extra batteries that are in the van. I can plug the van batteries into the AS from anderson connectors that are inside one of the battery boxes and a box mounted at the rear of the van. I use #2/0 welders wire for the battery connectors.
Everything works great. I have 1250 Amp hours or about 600 usuable when boondocking. But I can always recharge whith the 120 amp charger from the prosine inverter using the generator.
Old 11-21-2003, 03:28 PM   #28
Tinsel
Great rig.
Can you grace us with some pictures.
Neat.
jim
Texas
jim
Propane Powered EU2000i? Pick Generators & Solar Power 8 04-09-2016 06:36 AM
Generators . . . again? dinoburb Generators & Solar Power 6 03-18-2008 07:36 PM
Propane tanks question Swingking LP Gas, Piping, Tanks & Regulators 8 10-22-2003 09:55 PM
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 10:34 AM
Propane Usage COArgosy78 On The Road... 6 02-25-2003 09:35 PM
