Old 08-08-2016, 07:54 AM   #57
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
There is a propane tank adapter that provides two outlets. The are usually in stock at Amazon
Camco 59133 Brass 90 Tee with 3 ports
Lasco 17-5361 Propane Fitting Tee with 1-Male QCC and 2-Female QCC (several similar models)
Old 08-08-2016, 08:43 AM   #58
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Originally Posted by riffin-rich View Post
Doug, check www.genconnexdirect.com and www.motorsnorkel.com ... There are others too, but these are the two most popular, IMHO. genconnex does propane only and propane and/or natural gas ... US Carb (motorsnorkel) does all three (gasoline, propane and/or natural gas) but has an externally bolted on appendage. You need to visit the sites and query a lot to inform your decision. Rocinante's video earlier in this thread is awesome to show you the genconnex solution... Bottom line: only you can decide on your needs and compromises. Note I have neither yet. Good luck!
Regards,
Rich
Thanks for this rich:
I'm thinking i'm better off with the internal system coming from genconnect, They don't show a DIY kit for my EU3000i-handi on their site so I will try and call them today and see if they can help me. Because I already own the Honda 3000i-handi DIY seems to be my only option.
Thanks again for the links and comments
Cheers
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 08-08-2016, 12:30 PM   #59
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
I have the US Carb twin Yamahas tri-fuel 2000W inverters. I have used them on gas and propane, but not yet natural gas. They clearly run better on propane. I've had them for at least five years. Recently, we upgraded from a 2009 27' Flying Cloud FB to a 2015 Flying Cloud FB with dual air. Before going to the Region 10 rally in Kalispell, MT, I did a test run with the inverters and the A/C. They ran either A/C just fine but don't have enough power to run both so I didn't even try.
When we got to Kalispell rally, it was at the fairgrounds with limited power and water. It was in the low 90's and the elevation is about 3000'. The inverters would start either A/C but after a few minutes, the A/C would shut down. The inverters were supplied with a separate large propane tank and I checked their performance thinking the altitude might be affecting the power output. I did that by adjusting the air/fuel inlet valve watching the rpm. US Carb conversions come with rpm and hour meters. Any adjustment from its current setting reduced the rpm and the smooth running of the inverters.
So I'm at a loss to determine why the A/C would start, run for about 5 minutes (the compressor would kick in and cool air would start), and then shut down. The A/C fan would work but not the compressor.
In a recent Blue Beret article, there is a discussion about "hard start capacitor" conversion to the A/C which is supposed to work better when using the generators or inverters. Since my A/C will start but not maintain, I'm not sure the conversion is the answer.
I've been reading a lot about the use of these hard start capacitors and like the forums here, opinions are all over the board, even among so called career professionals.
Is there anyone here with similar experiences? I'm not trying to hijack this thread, but since for most the primary use is to be able to run an A/C, I think it appropriate for readers to know that there are issues to operation the A/C off generators and inverters.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 08-08-2016, 04:06 PM   #60
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Arctic fox.....the USCarb folks kit does work with your Honda EU300i Handi. I have the exact same generator and bought the kit while I was at the Lewisburg rally. It IS a bit more complex installing it into the 3000i, as you do need to loosen the carb which involves loosening a couple of other pieces to get to it. Anyway, they do sell a kit that fits and it works just fine. Barry
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 09-22-2017, 12:04 AM   #61
San Tan Valley , Arizona
Low Pressure External Port does not work with my Champion 3500/3100 Dual Fuel
I see others on this thread have been successful running propane generators using the external low pressure port of their AS. I have a 2017 International Serenity 19ft. I connected my Champion Dual Fuel 3500/3100 watt generator to the outside propane port using the 6 ft propane hose that came with the AS that I added a 3/8 quick connect male fitting to attach to the generator. This hose does not have a regulator and relies on the internal AS regulator. I could not get enough propane pressure necessary to run my generator. I called Airstream Customer Service and they told me the AS internal regulator has pressure of an 11 in column of water (the measurement the regulator gave to AS. The AS Customer Service person said the external propane port is only meant to use with a small propane stove/grill and does not have enough pressure to run a generator. I also tested the generator by removing one of the 30 gal propane tanks from the AS and using the 6 ft hose and regulator that came with the generator. That worked fine. Does anyone know what I can do to get the external propane port to work with my generator?
AZBob1 is offline   Reply With Quote
Old 09-22-2017, 01:55 AM   #62
Long Island , New York
Originally Posted by AZBob1 View Post
. . . Does anyone know what I can do to get the external propane port to work with my generator?
I don't think this is possible IMO. The only way is to do what you did, but you don't have to remove the tank from the trailer. Just get a longer hose for your gen, and use your regulator to attach the hose to one of the tanks.
You gen needs more propane at a higher pressure than the AS's low pressure port can supply. [IMO]
Some folks add an Easy Start device to one of the air conditioners, and use a 2000 watt gen/inverter off the low pressure port. There are tons of threads on this solution.
Good luck,
Peter
Old 09-22-2017, 03:04 PM   #63
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
Good luck,
Peter
Peter so for your setup on your FC20, from the low pressure port, you can run your Honda 1000 (I believe), and most if not all of the appliances (fur, WH, refer, oven/stove). What's your experience if any on what has to be throttled back/turned off while the genset is running?
CruizinDux is offline   Reply With Quote
Old 09-22-2017, 06:16 PM   #64
carbondale , Colorado
Now, I'm confused . Are the AS tanks with the external quick disconnect not capable of running a gen, either the honda 2000 or the yamaha 2400, or any other. Thats what I read from AZ bob report from AS customer service. I have been reading this whole thread believing people have been mostly using the two AS propane tanks. Answers???
capt_ron777 is offline   Reply With Quote
Old 09-22-2017, 06:56 PM   #65
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I have run my EU2000i from the quick disconnect I added to my trailer. It will provide enough propane for the generator at full power but I haven't tried to run anything else at the same time. The regulator is supposed to provide enough propane to maintain the 11" WC spec (about 0.4 psi) with all appliances operating.
The EU2000i is claimed to run 3.4 hours at full load on a gallon of gas. That would be equivalent to 114,000 BTU/3.4h or 33,500 BTU/h. The furnace in my trailer is 35,000 BTU. So I would guess that I could certainly run everything except the furnace while running the 2000i, and might even run the furnace depending on how much flow margin the regulator selected by Airstream has.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 09-22-2017, 06:56 PM   #66
Dave-n-Janet's Avatar
Moss Point , Mississippi
There has been a lot of discussion about this on some other threads. Basically the 3500 (or 3400) Champion has 2 regulators. To use the low-pressure disconnect, you have to take the small regulator (high pressure) off the Champion propane hose and get hardware to mate up with the quick disconnect. I have not used on the road yet, as my plan is to just fill the gas tank on the gen since at this point it is just backup. Should I need it and use up the 1.6 gal of gas, then I have propane. Also, living on the gulf coast in hurricane country, the 3500 watt Champion also gives me the options of gas (usually 5-10 gal around for lawn mower), propane (a couple of 20 lb BBQ tanks lying about) or the propane on AS should we ever have extended power outage.
Note - the AS low pressure is only rated for 25,000 BTUs, while the 3500 watt generator could pull more. May be a problem with extended use, I just don't know yet, although I haven't seen any problems reported on forum yet.
Dave-n-Janet is online now   Reply With Quote
Old 09-22-2017, 07:45 PM   #67
I have not really tested other propane-fired uses while the small Yamaha 1k inverter gen is running. I think the water heater may have run at the same time, but probably not the oven, range top burners, or the fridge (on propane), and definitely not the hot air furnace.
My guess would be that the trailer's propane system could handle almost all propane-fired uses at the same time, as the only one pulling off the low-pressure port is the small gen.
Sorry I don't have any usage/capacity stats available, nor the time or expertise to theorize. When the weather gets cold, I may try a full-scale test-run.
Have a good weekend.
Peter
Old 09-22-2017, 11:42 PM   #68
CruizinDux's Avatar
Peter
Peter thanks. No problem on the experience. I suspect you're correct, but things could easily be scaled back if needed. If you're using the oven the furnace would likely be overkill . And like you said with a longer house and two tanks....
Old 09-23-2017, 04:52 AM   #69
. . . And like you said with a longer house and two tanks....
Tanks for the suggestion, and
. . . tanks again!
Old 09-23-2017, 07:03 AM   #70
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
See post,#6 in this thread where Rocinante quoted a number of prior posts including mine. A few thoughts on the recent additions to this thread:
- The low pressure port on our 2014 model trailer is rated for devices of up to 25,000 BTUs. I have not attempted to calculate a BTU rating for generators, but I recall someone on the Forums did and concluded that a single 2000 watt generator would exceed the rating. In other words, Airstream isn't claiming we should be able to meet our trailers' electric needs with the power from that port.
- The factory installed port on our trailer is an MB Sturgis model 250 low pressure propane disconnect (or equivalent... in any event, fittings that comply with that standard seem to be compatible with our trailer). This is a 1/4" series brass fitting. I know that many generators (including my two Honda's with the PropaneCarbs.com conversion kits) use 3/8" rubber tubing. Note that the port itself is a bottleneck in a system plumbed with 3/8" tubing.
- I have run tests with two Honda 2000s running simultaneously at full throttle off the trailer's low pressure port using a 1/4" tee. That's documented in the post Rocinante linked to, I believe. I had every propane source in the trailer running at the same time including the furnace and all three stove burners. The generators still produced 120 volts to the trailer's 120 volt system.
- Propane evaporation is strongly affected by ambient temperature. When I ran my tests, it was a warm day in Florida. Clearly, I was exceeding the design limits of the system as Airstream expressed them. I doubt that test could be repeated with the same results at colder temps. I would not advocate running that much propane load on the system at once, but for my own purposes I wanted to see if the system was capable of it. In practice, I do run both generators simultaneously off the trailer's low pressure port with a tee fitting and 10' Camco extension hose successfully, but I turn off all other propane loads when I do that. Note, I only need that much generator capacity to run my AC, so by definition it is hot when I do that and the heat supports higher levels of propane evaporation from the active 30 pound tank.
- I appreciate that the Forums have become prime advertising space for EasyStart products as the solution to generator capacity issues. Note that the specs on some Dometic Penguin II models indicate that a "2000 watt" generator (the Honda 2000's are actually rated at 1600 watts continuous output) or even 2400 watt models may not maintain full 120 volt output with the AC running and certainly would not if any other load is present... even the trailer's converter. Voltage drop is a sign that the electric load is exceeding the capacity of the source. If I was attempting to cut corners on generator capacity I would make sure I had a surge protector with a low voltage shutoff between the generators and all of the electric/electronic stuff in my trailer. That may just be me.
- Although I have not had an issue with our Airstream, there are many posts in the Forums about primary regulators delivering more or less pressure to the system than the stated "11 inches of water column" that the book says. In my opinion, if tests like people mentioned above did not work, the first thing I would check is whether the trailer's low pressure system was actually at 11 inches. Primary regulators are often adjustable and are certainly replacable. If the pressure wasn't at or very close to 11 inches, I'd get that addressed before drawing any other conclusions.
GammaDog is offline   Reply With Quote
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 04:22 PM
any residents of Sequim ,Port Townsend or Port Angeles kingfisher24 On The Road... 6 10-15-2013 09:57 AM
Champion 73531i Generator Experiences Anyone? eberrobw Generators & Solar Power 12 07-16-2011 11:05 AM
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 02:04 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 07:29 PM
