Old 07-13-2016, 07:06 PM   #29
Long Island , New York
Originally Posted by Adiredneck View Post
Following. I just received my two Yamaha 2000 tri-fuels from USCarb yesterday. There were a couple of features that I liked better than on the Honda, but to each their own. Full warranty on Yamaha because USC is a licensed dealer. Interested in reading about using the quick-connect and various plumbing combinations, as that is the next step in my project/education. Good thread...!
We got 2 10' quick-connect hoses with shut-offs which worked with our OEM FC20 low pressure propane port and the new Yamaha 1000, which comes with various brass bushings to make this work. You have to get some pipe dope and propane-rated Teflon tape. Easy.
10' hose: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Male quick-connect needed at gen bushing: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
[ The parts you need may be different -- YMMV ]
Two of these connect to get the gen behind the trailer near the back or sides of most sites -- whichever makes for the quietest run. We even stuck the gen in the back of the van once, with moving pads loosely around part of it, to muffle the sound.
See Post #6 (and later) in this thread for more detail:
http://www.airforums.com/forums/f448...ay-150492.html
We have used the Yamaha 1000 on three recent trips, and the sound of the ocean at the CG was much louder than the gen. Nice!
Good luck.
Peter
Old 07-14-2016, 07:09 AM   #30
KJRitchie's Avatar
2008 25' Classic
Nixa , Missouri
Originally Posted by Rocinante View Post
Not sure why it says that. Mine is already en-route from them, according to UPS.
I contacted them via their contact page last night and they responded very quickly. If ordered this week it would be delivered by next week.
I'm liking this design over the others. I can just see an externally mounted regulator getting damaged when the generator is jammed in the back of the truck unless its in a plastic box. I'd prefer hauling a 20lb propane tank vs 3 to 5 gallons of gas not to mention having to worry about the carburetor getting fowled by bad or old fuel. I can use the propane tank for the BBQ and the propane campfire too.
I guess buying a new modified generator voids the factory warranty.
The RV1 and RV2 are identical kits except the RV2 has the grounding receptacle. What happens if I just connect my 30amp shore power cable to the generator via a 30amp to 15amp pigtail adapter?
Kelvin
2010 Tundra 5.7L, Double Cab, 2wd, White
Old 07-14-2016, 07:39 AM   #31
Not for the Yamaha units. Is there some reason you would not consider a Yamaha from US Carb, Kelvin, or from some other vendor? Other AS owners here have gone that route, and seem pleased, as linked in earlier posts on this thread.
Peter
PS -- Edit -- OK I guess your objection to the externally mounted equipment refers to the Yamahas.
Old 07-14-2016, 08:13 AM   #32
KJRitchie's Avatar
2008 25' Classic
Nixa , Missouri
I think the Genconnex is the only one that puts the regulator inside the case which is appealing to me.
I wonder why Yamaha would warranty such a drastic modification?
One thing I've read about Yamaha their dealer network isn't as extensive as Hondas if anything should happen but then with the Genconnex generator you would have to ship the generator back to them for any warranty work. They offer a 3yr warranty.
Kelvin
Old 07-14-2016, 09:47 AM   #33
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Western WA , Washington
Propane generator on Airstream's low pressure port - Actual Experiences, please.
Re: warranty. Yes, this voids the Honda warranty, though Genconnex warrants them. Not the same, we fully realize.
Meanwhile, the sales rep from US Carb told us their mod *also* voids the manufacturer's warranty. (Before anybody gets huffy about that please know he put this in writing to us via an email, and so we chose to believe him.)
So, for us the warranty question was a wash, we didn't care about tri-fuel, and we liked the simple elegance of the Genconnex solution. Your priorities and resulting choices may differ. 😎
Soon we hope to post about our actual experience with our generator vs. chit-chatting and armchair quarterbacking on the subject. 😏
Rocinante is our 2014 International Signature 27FB
Old 07-14-2016, 10:11 AM   #34
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Kelvin
Some surge suppressors and transfer switches will not pass power from a generator that does not have the neutral connected to the safety ground. My eU2000i does not, but I have neither a surge suppressor nor transfer switch. I don't know what your trailer has. If you have a surge suppressor or two shore power connectors you probably need the grounded receptacle, but you can make one easily if there is a significant cost difference. Simply take a plug and connect a wire from the silver screw (neutral) to the green screw (ground) and plug it in to the other socket on your generator.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 07-14-2016, 10:40 AM   #35
2015 25' FB Flying Cloud
Sandy , Utah
Anyone notice that Propane costs more than gas? In my area it is 70 cents a gallon more than gas. Plus you have the cost of the conversion. I do buy into the convenience thing. It would be very handy to just plug in and not have to pack a gas can. In my case I have a pickup so the generators "live" in the back of the truck along with the gas can.However for someone with an SUV TV a Generator mounted on top of the Battery Box running on Propane would be the way to go.
rocco52 is offline   Reply With Quote
Old 07-14-2016, 10:43 AM   #36
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Just to clarify the US Carb warranty statement on the Yamaha generators. It does not void the Yamaha warranty, however they do have the right to refuse a warranty claim if they feel that the claim was caused by the fuel modification. I'm comfortable enough with Yamaha's coverage and knowledge that the tri-fuel conversion is engineered well. Quite honestly if Yamaha had experience problems with this conversion, they would have pulled the warranty some time ago. With all things being equal, I probably would have gone with Honda only because of my experience with Honda products. The lack of warranty however was a deal breaker and I'm perfectly happy with my Yamaha choice. I bought the Yamaha new from US Carb with the tri-fuel kit installed by them. US Carb registered the generator directly with Yamaha and a few weeks later I received a free one year warranty extension from Yamaha. Don't know how long that warranty extension deal will last but I do feel good about the 4 years of protection.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-14-2016, 11:31 AM   #37
Rivet Slave
Rocinante's Avatar
Sorry, rocco52, this is armchair quarterbacking of the worst and least helpful sort. You may want to read the first post to understand why I as the OP don't want a gasoline-fired generator. The cost of fuel was not an issue. Let's move on, shall we? If you want to talk gasoline vs. propane as an argument thread, feel free to start a different discussion.
Oh, JCanavera, thanks for posting your actual experience re: the warranty on a tri-fuel generator. Perhaps our sales rep there was misinformed. Too bad, it probably cost him a sale.
Old 07-14-2016, 12:40 PM   #38
Ditto to Jack Canavera on the Yamaha warranty from US Carb. We recently got ours with the 1-year extension in the mail.
Peter
Old 07-15-2016, 01:43 PM   #39
Rivet Slave
Rocinante's Avatar
One more excellent post I found on another thread regarding actual experiences, this one showing how to connect two propane-fired generators to the low-pressure port.
Originally Posted by SteveSueMac View Post
We got the kits from Genconnex for our pair of Honda 2000s. We got 3 hoses with the kits.
Two of them are meant to connect directly from the LP tanks to the generators. They have a regulator built in to the hose (low vs high pressure was mentioned earlier). Note the tank threaded fitting on one end and the 3/8" female quick disconnect fitting on the other. The Genconnex kit has a 3/8" male QD fitting on the generator.
We got one of these with each generator:
Attachment 263994
Also, I FINALLY got my Weber Q120 converted as well and had the Torjik folks ( http://torjik.com/#_convertaq ) create a custom hose to connect to a 3/8" fitting as well. So I can use this hose to run the Weber from my AS LP tanks or a 20# tank away from the AS (like at home). These hoses also allow me to run the generator from home off a 20# tank should that be needed.
Genconnex also custom-made a 3rd hose for me to connect from the RV port (1/4" quick disconnect) to a T fitting that splits off to feed the pair of connected generators with a 3/8" fitting. Each hose input to the generator has its own on/off valve so in theory I could run one generator off the RV port and close the other line, or even run the grill off the other line.
Attachment 263995
You can definitely do either/both if you like.
Old 07-20-2016, 12:06 AM   #40
Rivet Slave
Rocinante's Avatar
Just posted our unboxing / setup video for the GenConnex-enhanced Honda Eu2000i Companion: http://www.casarocinante.com/Blog-As...deos/i-8NPvBvs
We're very pleased with this unit.
Old 07-30-2016, 10:16 AM   #41
TinVenture's Avatar
2016 19' International
Orange County , California
Originally Posted by GammaDog View Post
GammaDog here. You found my post. Nothing new to add. I was amazed that the single QD on the trailer can run two Honda 2000s in parallel with all three stove burners, the fridge and the water heater running at the same time... but it can.
I had another post or three on this subject including the parts for the QD tee and propane consumption rates. Let me know if you need any of that.
I want to use a similar set up to what you used but with one Yamaha 3000 generator. I talked with the guys over at GenConneX as this is what they had to say:
"Sorry but yes, you have a problem indeed. The problem is not just the size
of the quick-disconnect but of the pipe going from your tanks to that quick
disconnect (probably also 1/4id). Both need to be increased in size to 3/8"
to handle the throughput of propane. Otherwise the generator will shut off
or run very poorly under load.
Gary
Sales - GenConneX™Direct"
I'll attach a chart from the US Carburetion website referencing the amount of BTU pulled by generator size.
There is a label next to the LPG which states to not exceed 25,000 BTU. I would prefer to run my generator off the LPG port but concerned about thr 1/4" hose and exceeding the manufactures recommendation of BTU.
TinVenture is offline   Reply With Quote
Old 07-30-2016, 03:19 PM   #42
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We attached our 2000 watt Honda with the 30 amp power outlet to the front propane port on our 2015 23D International Serenity. Used a custom 30 amp twist-lok power cord between the generator with the GenConnex kit and our retrofitted 30 amp power inlet on the front of the 23D.
We have the hybrid Magnum MSH-3012 inverter which pulls the added needed current to start the air conditioner. The single generator is thus able to run the air conditioner. The five 100 watt solar panels refresh the 300 amp hour lithium battery and keep it topped off.
The system works well for us.
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
any residents of Sequim ,Port Townsend or Port Angeles kingfisher24 On The Road... 6 10-15-2013 08:57 AM
Champion 73531i Generator Experiences Anyone? eberrobw Generators & Solar Power 12 07-16-2011 10:05 AM
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 01:04 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
