Propane conversion with Honda 2000EU
I have limited use with my US Carburetor conversion of Honda 2000 which is gas/propane capable-- under $200. Wet gas in the winter pushed me to convert and the kit is well instructed and is largely external. The regulator is needs to be next to the generator, and the valve control is sensitive. Once set, the starting is reliable and much better in the cold. No more gas to haul, and tap the propane tanks with "Y-valve". I tap straight in the tank as auxiliary tap for grill is small er flow than recommended. Have not measured the flow rate-- use a lot more propane in the winter with the furnace.
