Old 05-20-2011, 05:04 AM   #15
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I've had a Yamaha 2400, that I bought converted, for about four years. I don't use it that often, but I've had no problems when I do. I added a flexible line with quick disconnects to the Airstream LP tanks and I use that for the generator and BBQ.
Old 05-20-2011, 06:03 PM   #16
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Originally Posted by Gringo View Post
Is that liquid gallons, or gallons of vapor? It would be interesting to know if that makes a difference. I mean,if it takes 1 oz of liquid gasoline vaporized to fill the cylinder of an internal combustion engine with the ideal gasoline to air ratio for the best combustion, would it also take 1 oz of liquid propane to fill that cylinder with the ideal combustion ratio of propane to air?
I guess another way to look at it would be by weight. 20 lbs of gasoline would be 3.29 gallons, at 6.073 lbs. per US gallon .
How long will a generator run on 3.29 gallons of gasoline vs how long will it run on 20 lbs of propane, with the same electrical loads?
Don't mind me. I'm on the espresso this morning....
My numbers are based on liquid gallons...
Aaron
WBCCI #XXXX AIR #2495
Propane phobia. ROBERTSUNRUS LP Gas, Piping, Tanks & Regulators 18 04-27-2011 11:37 AM
Propane go boom SpaceEgg LP Gas, Piping, Tanks & Regulators 4 02-28-2011 12:05 PM
Rear Propane Tanks? Rob&Julie LP Gas, Piping, Tanks & Regulators 7 02-12-2011 05:38 AM
