03-21-2017, 07:48 PM
#21
2017 25' Flying Cloud
Florence
, Alabama
Originally Posted by GammaDog
Plenty of threads and pics on this subject on the Forums. Here are answers to some questions above:
I run two Honda 2000s on propane from the LP port of the trailer. I'm not saying you should... they exceed the 25,000 BTU rating of the port... but for me it works at least in the Florida heat. Naturally, a tee is required to split the single LP port connection into two. There's a pic of that in my gallery and a post somewhere (maybe Google 'airforums gammadog lp quick disconnect' to find it) describing all of the parts. PM me if you need info on that.
The factory installed port on the recent model Airstreams is an MB Sturgis model 250. It is a 1/4" fitting. Many generator kits use 3/8 hoses. Naturally, the 1/4" fitting is a bottleneck. It has not proven to be a problem in practice for me. Your mileage may vary.
Many kits have no provision to use high pressure propane directly. In other words, you can connect to your LP port but not directly to a propane cylinder. Consider getting a regulator for your generator so you can use it from a 20 pound cylinder away from the trailer if you ever want to. Check my gallery. Our two Honda's and two 20 pound cylinders ride on a platform under the tonneau. I can run either or both of them from the 20 pounders or the trailer. I can also backfeed the trailer through its LP port from any propane source. It all works usng those MB Sturgis model 250 quick disconnects, so I can snap it together quickly in any configuration.
Expect to burn about 2 pounds of propane per hour per Honda 2000 at full throttle.
Many companies make kits for the Honda 3000 as well. I used (and have been happy with) Propane Carbs kit. There are lots of great comments on the Forums about many other kits, too. I'd believe those folks. My sense is there are many quality options out there.
I hope that helps
Thx [emoji106]
The Colonel and Southern Belle
03-21-2017, 07:51 PM
#22
Florence
, Alabama
Originally Posted by dblee1950
Well, my situation is simpler. I use charcoal so just want to go from AS bbq out to Honda propane converted in.
Pulled the trigger on a single Honda conversion kit from genconnex. Happy hour makes me more risk seeking.
03-22-2017, 06:17 AM
#23
Biloxi
, Mississippi
Originally Posted by VaTravelers
One other thing, some of the conversion kits hang outside the generator which makes them susceptible to damage.
Curious, have you ever read or heard of an externally mounted conversion unit being damaged?
MICHAEL
03-22-2017, 06:53 AM
#24
Florence
, Alabama
I hope that helps
That looks like the hose setup I need. Honda gen female and the 1/4 male end for the low pressure port at front of AS. Where did you get your hose with those fittings?
03-22-2017, 07:04 AM
#25
Florence
, Alabama
03-22-2017, 08:11 AM
#26
Journeyman
2016 25' International
Amherst
, Massachusetts
That's a good place to start, but it's got 1/4 inch connections on both ends... and the genny is 3/8.
I made my hose last night. The hose I made works with the genny (3/8") but you can easily disconnect that bit to return it to 1/4" use (which is what I will put on my grill).
Here is the detail with a photo and links to the products you need:
http://www.introductiontoeverything....y-rvs-lp-port/
03-22-2017, 10:00 AM
#27
Florence
, Alabama
Thx, this gives me something to work with
03-22-2017, 10:09 AM
#28
2019 27' Globetrotter
Salem
, Oregon
I just went to my local propane dealer and they made up the longer hose with the proper fittings.
Dave
03-22-2017, 10:22 AM
#29
Salem
, Oregon
Chief and any else thats interested. I mounted my regulator on a plexiglass sheet and put holes in the bottom for the generator feet. The generator just sits on it. \\
Somewhere here on the forums I have a picture. I will try to find it as I have a hard time posting pictures.
Dave
03-22-2017, 10:25 AM
#30
Journeyman
Amherst
, Massachusetts
Dave
Definitely an option. I wanted to be able to use just one hose for both the grill and the genny, so this preserves my flexibility...
#31
Florence
, Alabama
I checked here and no joy. I called genconnex and they have a 1/4 to 3/8 setup 12' long that looks like it will work. Under 1/4" hoses
03-22-2017, 11:34 AM
#32
Florence
, Alabama
Dave
I wouldn't mind having a look at that setup. Sounds interesting.
03-23-2017, 10:13 AM
#33
Salem
, Oregon
03-23-2017, 10:16 AM
#34
Salem
, Oregon
03-30-2017, 04:16 PM
#35
Florence
, Alabama
Got my 2 H gens in and a conversion kit. A bit challenging but an hour + and a couple of phone calls and it's done. Got to get synthetic oil in am and will check it out.
04-01-2017, 02:02 PM
#36
Florence
, Alabama
Just before leaving on a trip, I serviced my converted H2000 with synthetic oil and hooked it up to my LPP on the front. Purged the air from the hose and a few pulls it started. Hooked it up to the AS and applied power. Worked! Further testing when I get home.
04-03-2017, 08:52 PM
#37
2017 28' International
Virginia Beach
, Virginia
I actually don't have a specific example. Just saying the probability is greater that you might have a problem if the regulator is attached on the outside of the generator as opposed to being enclosed inside the case.
04-04-2017, 09:40 AM
#38
Salem
, Oregon
See my post #34 I have the regulator attached to a plexiglass sheet that I carry separate from the generator along with miscellaneous things. When using the generator I just sit it on the plexiglass and hook up my quick connect hose.
Dave
04-04-2017, 04:24 PM
#39
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
Originally Posted by thiel
Enjoyed your post on this as well as the Weber Q conversion.
With this kit, could you plug right into the low pressure port on the AS or did you need to get a different hose? The photo on the manufacture website appears to be a hose with a high pressure fitting and regulator on it. For $350, do I need to spend more working up a hose.
Thanks again.
04-04-2017, 04:30 PM
#40
The Aluminum Tent 3
Park City
, Utah
Disregard my last post with the question about the connector hose! Thanks for this.
