We just purchased the Honda EU2000i Inverter Generator Combo Package. Our towing vehicle is a Ford F150. Can we leave both generators running while they are sitting on the back of the truck bed?
This seems like a simple question, be we just can't seem to find a definitive answer.
Thank you all for your help, we very much appreciate it.
My husband is thinking the engine might get hot after running for hours, and the hot engine might get too hot on the truck bed liner. The instructions say the generator should be cooled by allowing 3 feet of empty space above and around the generator.
So obviously it's okay if the generator is on the ground. But we just weren't sure if it was sitting on the back of the truck.
The fact you've been doing it for years is probably telling us it's okay.
I do it, but would make sure which direction the exhaust is pointed, I know someone that melted the vinyl siding on their house because the generator exhaust was too close...
Aaron
WBCCI #XXXX AIR #2495
We run ours on the tailgate all the time. I just turn it so the exhaust is pointed out to the side. Got a poly feed pan from Farm & Fleet for the gen to sit in. The pan makes it easy to slide in and out. I built a cart the same height as the tailgate so when it's time to take the gen out of the truck I just have to slide it from the tailgate to the cart and roll it away.
__________________ Tim
TAC MI 14
Everyday is a Saturday
We run our generators in the bed or on the tail gate from time to time, especially if it's going to be raining ... In the rain we leave the tonneau top closed with the tail gate down and the exhausted pointed outward ... the important thing is to have enough circulation around the genrator to get good air flow/ventilation.
The Honda EU2000i pulls in cooling air from the bottom sides, so it's important that area be kept clear.
There's a thermal-type circuit protector that will shut down the electrical side of the generator if it gets too hot from making power, but the engine will continue to run, so it is important it have a good source of free air for cooling.
The 3-foot spacing is conservative, but a good rule of thumb to use. Probably more important is to not operate them unattended.
Robert@Honda
Social Media Consigliere
Caveat: I work for Honda, but the preceding is my opinion alone.
2015 30' Classic
2012 28' International
Greensboro
, North Carolina
I've seen quite a few folks pull into a campground with their two Honda's running and their A/C on. Since I have an SUV, I don't have that option...but I sure do use them if I'm boon docking and it's hot out.
In the bed of the truck, with a topper? It's a generator, right? Get a small 120v fan, plug it in to the generator, and let it blow on it. I know, too easy...
I would prefer to do this at the back end of the trailer (to avoid fumes) but couldn't at this particular site. I use a folding table covered on 3 sides w/tarp. This particular weekend was 50% rain but we had no trouble with this setup.
