Old 06-24-2013, 09:47 PM   #1
time2play's Avatar
2013 30' Classic
Kent , Washington
Powering on the Honda Generator
We just purchased the Honda EU2000i Inverter Generator Combo Package. Our towing vehicle is a Ford F150. Can we leave both generators running while they are sitting on the back of the truck bed?
This seems like a simple question, be we just can't seem to find a definitive answer.
Thank you all for your help, we very much appreciate it.
time2play is offline   Reply With Quote
Old 06-24-2013, 10:07 PM   #2
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Why not?
Need more info on your thinking - why do you think it might be not all right.
Been doing it for years, am I missing something?
Silver Hawk is offline   Reply With Quote
Old 06-24-2013, 10:21 PM   #3
time2play's Avatar
2013 30' Classic
Kent , Washington
Sorry for not clarifying my question more.
My husband is thinking the engine might get hot after running for hours, and the hot engine might get too hot on the truck bed liner. The instructions say the generator should be cooled by allowing 3 feet of empty space above and around the generator.
So obviously it's okay if the generator is on the ground. But we just weren't sure if it was sitting on the back of the truck.
The fact you've been doing it for years is probably telling us it's okay.
So thank you Silver Hawk for your answer!!
Old 06-24-2013, 10:53 PM   #4
1986 31' Sovereign
Miami , Florida
Been doing it for years. I have Rhino lining and it isn't even warm to the touch under my Honda.
Mike
Old 06-25-2013, 04:28 AM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I do it, but would make sure which direction the exhaust is pointed, I know someone that melted the vinyl siding on their house because the generator exhaust was too close...
Aaron
WBCCI #XXXX AIR #2495
Old 06-25-2013, 04:37 AM   #6
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Is your trailer a front bedroom? If so, make sure the exhaust is not firing right at your bedroom windows.
Old 06-25-2013, 04:49 AM   #7
"Cloudsplitter"
On the bed.....
....not in, no cap. I wouldn't worry as far as heat goes. Keep all truck windows closed.
We use a small 3 person tent, out of sight and weather.
Name:	PISECO LAKE CAMPING JULY 2008 140.jpg
Old 06-25-2013, 05:21 AM   #8
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Those generators do not get hot, aside from the exhaust output of course. Good luck!
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 06-25-2013, 06:31 AM   #9
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
We run ours on the tailgate all the time. I just turn it so the exhaust is pointed out to the side. Got a poly feed pan from Farm & Fleet for the gen to sit in. The pan makes it easy to slide in and out. I built a cart the same height as the tailgate so when it's time to take the gen out of the truck I just have to slide it from the tailgate to the cart and roll it away.
ID:	189256   Click image for larger version
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 06-25-2013, 12:58 PM   #10
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We run our generators in the bed or on the tail gate from time to time, especially if it's going to be raining ... In the rain we leave the tonneau top closed with the tail gate down and the exhausted pointed outward ... the important thing is to have enough circulation around the genrator to get good air flow/ventilation.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Old 06-25-2013, 01:51 PM   #11
robert@honda's Avatar
Alpharetta , Georgia
The Honda EU2000i pulls in cooling air from the bottom sides, so it's important that area be kept clear.
There's a thermal-type circuit protector that will shut down the electrical side of the generator if it gets too hot from making power, but the engine will continue to run, so it is important it have a good source of free air for cooling.
The 3-foot spacing is conservative, but a good rule of thumb to use. Probably more important is to not operate them unattended.
Robert@Honda
Social Media Consigliere
Caveat: I work for Honda, but the preceding is my opinion alone.
robert@honda is offline   Reply With Quote
Old 06-25-2013, 04:28 PM   #12
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I've seen quite a few folks pull into a campground with their two Honda's running and their A/C on. Since I have an SUV, I don't have that option...but I sure do use them if I'm boon docking and it's hot out.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 06-25-2013, 04:57 PM   #13
Retired.
. , At Large
In the bed of the truck, with a topper? It's a generator, right? Get a small 120v fan, plug it in to the generator, and let it blow on it. I know, too easy...
Old 06-25-2013, 05:02 PM   #14
interstateflyer's Avatar
2017 25' International
Los Osos , California
Be careful with gasoline if you have a plastic bed liner. It is not grounded and there is a risk of fire when pouring gas. Do it on the ground.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 06-25-2013, 05:30 PM   #15
W , New England
I would prefer to do this at the back end of the trailer (to avoid fumes) but couldn't at this particular site. I use a folding table covered on 3 sides w/tarp. This particular weekend was 50% rain but we had no trouble with this setup.
Old 06-25-2013, 05:31 PM   #16
"Cloudsplitter"
LPG....
Old 06-25-2013, 06:10 PM   #17
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Attachment 189280
We've dome that before using a kid's card table that we normally use as a side table in the patio area. Works great!
AirForums #21900
PastPrez, 4CU/WBCCI
