Old 03-02-2013, 12:14 PM   #1
Tonganoxie , Kansas
Power Source Solar Generator
I cam across this ad in Mother Earth News for a 1800 watt solar portable generator. Their web site is Solar Generator - Amazing Solar Generator Is Like Having A Secret Power Plant Hidden In Your Home and the company is Solutions from Science.
Anybody know anything about this company or their product. I have been reading a lot about solar here on the forum and other places and am still a electronic idiot. It sounds good, but then what do I know.
Stan
TWA640316 is offline   Reply With Quote
Old 03-02-2013, 12:24 PM   #2
The inverter is 1800 watts, but the solar panel and battery will limit you on
efficiency. It might power your lights, small applicances like a coffee maker as long as you turn it off when it quits brewing, and other low amperage applicances. Definetly not your AC unit and furnace fans.
0557 is offline   Reply With Quote
Old 03-02-2013, 12:54 PM   #3
2000 31' Land Yacht
Fort Erie , Ontario
It's all in the details, below are the specifications. Note that solar charging is 5 amps max! How to specify your needs? Check solar use in the forum.
Steve
- SPECIFICATIONS -----------------------------------
OUTPUT - Output power (maximum) : 1800 W (2900 VA)
Surge power (peak) : 3600 W
Output voltage (nominal) : 120 VAC
Output frequency : 60 Hz +/-1 Hz
Output wave form : Modified sine wave
Transfer switch : 15 A maximum/<80 milliseconds
Surge suppression : Yes
Inverter on : < 0.6 A (battery drain)
(no-load current draw)
Charging time : 15 hours from 120 VAC
12 VOLT DC - Internal battery type : Sealed lead acid, AGM
Internal battery capacity: 60 amp-hours
Internal battery voltage : 12 VDC (nominal)
Low battery alarm : 11.0 V (nominal)
Low battery shutdown : 10.5 V (nominal)
Internal charger
charging current: 5 A DC maximum
APPROVALS - UL, CSA, FCC B
DIMENSIONS - 8.5"w x 18.5"h x 10.5"d WT.- 65 lbs.
is.chowa is offline   Reply With Quote
