Old 01-28-2016, 11:41 AM   #1
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Portable solar panel table
Just launching an idea to the web to see what happens. Has anybody thought about taking a rigid 50 or 100 w solar panel and using it to make a portable table. It seems like it could be pretty awesome.Most panels have strong aluminum frames and a robust glass top. If you built the legs right, they could fold up flat when not in use and maybe could even be designed to allow you to tilt the panel.
My solar panels are glued to the roof of my Airstream, but I am worried about how to maintain my batteries when I am parked in a shady spot. I was thinking about buying a separate panel that could go anywhere, but don't have much extra storage space for something that big. If it could double dip as a small table, it might be useful enough to make the cut. I am not sure how I'd connect the panel to the controller. Are there any waterproof DC plugs that could mount on the exterior skin near the power center so I could run an MC4 cable out to the panel location in the sun?
Tim
timzog is offline   Reply With Quote
Old 01-28-2016, 12:56 PM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I've observed many RV'ers with portable solar panels. This arrangement offers the advantage of positioning the panels best to catch the rays especially if you are in shade. So this is not a new concept.
I've never seen one used as a real table, however. Obviously it's ability to absorb solar energy when used in such a manner would be basically negated.
The principal disadvantages of the portable solar panels as far as I can tell is storage while underway and possibly theft while unattended.
Bob Martel
WBCCI# 5766
Old 01-29-2016, 08:03 AM   #3
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
I agree that it wouldn't get power when you were eating, but we usually don't spend much time using the table in the middle of the day. We mostly hang around at the table at breakfast and dinner so I don't think you'd lose too much power that way.
Old 01-29-2016, 08:22 AM   #4
Tn Traveler's Avatar
2006 25' Safari
Signal Mountain , Tennessee
I have an eighty wall portable solar panel. I have a 50' extension chord to move it around to catch the sun. It has an attached leg stand for the proper angle, and I cable and lock it to a tree. It really does work. The controller is not the most efficient, but the whole thing resides in the battery box. I look for shady spots for a campsite. It stores in a box in the Suburban while travelling.
I just installed a 1 1/2 am battery minder to keep the batteries charged during indoor storage. It cuts off automatically when fully charged.
Don
'06 Safari 25 LS
'18 GMC 2500HD Duramax/Allison
TN, Greenest State in the Land of the Free
" America is not a place;it's a road." Mark Twain
Tn Traveler is offline   Reply With Quote
Old 01-29-2016, 11:19 AM   #5
1973 31' Excella 500
Calgary , Alberta
I used PVC pipe to make a stand that holds the panels at a 45 to get the most sunlight. I have a 30" cord running to the controller. It all comes apart to a nice small size. It has worked well for shady spots.
Remember the impossible only takes a little longer.
DaKs is offline   Reply With Quote
Old 01-29-2016, 11:49 AM   #6
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
I would not use the bare panel as a table. Maybe with a thin piece of veneer over the top, that could double as storage protection.
The best idea I've seen for big panels used as portables was a two wheel golf cart to move it around and track the sun.
Old 01-29-2016, 12:43 PM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
That has potential, especially if the veneer cover is attached with a piano hinge, and has a reflective underside, so that you could prop it open and use the reflector to aim more sunlight at the panel for those days when the amount of sunlight is less than optimal.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-29-2016, 02:39 PM   #8
^^ I like that idea. I use garden mirrors to throw more light on my vegetables. Similar idea.
OP, the Grape Solar panels we just bought would not be robust enough in and of themselves to be used as a table, but if you were to fashion a frame and legs out of a material such as 80/20, and pair that with a protective top, you might be onto something. Available 80/20 components include hinges, so the legs could be made to fold up. If interested, you can see what one kind of 80/20 solar panel frame looks like here:
http://www.interstateblog.blogspot.c...on-part-2.html
Portable Solar Panel Battery Charger Mrjkq Electrical - Systems, Generators, Batteries & Solar 10 08-09-2015 08:22 AM
credenza, dining table, small table for top of credenza, small table from other side of trailer janeinthemtns Airstream Classifieds 1 09-25-2014 05:24 PM
falling table leaf of credenza fold-away table Fenghuang Cabinets, Counter Tops & Furnishings 3 02-13-2007 10:27 AM
Portable table mcneon Off Topic Forum 6 11-28-2004 08:26 PM
