Originally Posted by 2airishuman
most of the back hatches are tall enough to fit a generator...2air'
of course this is supposed to read...
"most of the back hatches are
NOT tall enough to fit a generator"
sorry for the poor proof read.....
larry...
keep in mind pick has propane tanks for fumigation of his diesel truck. so he's commited to propane for other reasons...
i've posted elsewhere on noise levels of the common generators....
have you read somewhere that noise levels change for converted units?
i don't understand how that would happen unless rpms are modified somehow.
the combustion chamber hasn't changed...
since lpg contains slightly less energy than gasoline,
i've read conversions reduce kwatts 5% or so...
i don't know if that is really true or if converted units run at a higher rpm for a given load...
which would increase noise but still be within the measured levels...
my understanding is that honda under rates their units true output...
so again conversion shouldn't limit generator capacity....
conversion is easy with the kits...i use mine so much away from tanks that carry the lp stuff would be a bother....
picnics, hiking, biking...the genset is just there ready to provide juice. a full tank of gasoline lasts 6-12 hours for me....
cheers
2air'
