Old 10-12-2006, 09:48 AM   #15
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
Originally Posted by jglabrown
Because our 16' Bambi carries only a series-24 battery which can be expended in one 24-hour period, we carry a Honda 2000 generator. We trailer with an SUV, and given the fumes and potential for fire, carrying the generator in the vehicle is not an option. Likewise, carrying gasoline on a rack either in front or in back of the car or trailer has never seemed like a good idea - one good rear-ender could make headlines! The only thing I've been able to come up with is placing the generator just inside the door of the trailer. Last thing loaded and first thing out. If something does happen, at least people in the car are somewhat protected.
So far, this arrangement has worked well, but I'm wide open to suggestion.
(one of the nice things about the Honda is that with the cap vent closed, the thing can be turned inverted and still not leak)
Larry
Think about a propane conversion.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 10-12-2006, 08:57 PM   #16
jglabrown's Avatar
2005 16' International CCD
2009 23' International
Bainbridge Island , Washington
Hmm...I truly hadn't considered that. When I logged on and saw your reply, I searched under "propane generator conversions" and found a really good thread from last year (2005). Had to gulp a couple of times when the discussion got around to drilling out the high speed jet, but was able to relax some a couple of posts later when someone said they had their Honda dealer take care of it. Most of my questions were covered in that thread, but I am curious what the conversion does to the already-low dB level?
jglabrown is offline   Reply With Quote
Old 10-12-2006, 09:07 PM   #17
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I just got and ran a Yamaha pre-configured to run on propane only 1000 watt generator.
For 6 hours of use, it used next to nothing in terms of fuel. I had the fridge, 2 fantastic vents runnning at speed level 3, the stereo (w/ 100 watt sub on) and several lights and was a bit more than half the 1000 watt limit.
It wouldn't power the A/C unit, but I knew that before I got it. It also won't run the microwave and most likely won't run a convection over either.
I ran a 960 watt electric chain saw off it (not while connected to the Safari) and it did a wonderful job.
Best part is I can keep it in the Suburban while in transit and there are no foul odors, no extra containers I need to put it in, just throw it in the back and go.
Right now US Carb has the Yamaha pre-built with the propane option. Comes with battery charging cables and a tachometer/hourmeter standard. Any model you choose will cost more than any non-propane converted generator, but in my tests this past week, it was worth it.
If you need more power, I would suggest the propane powered 2000 watt Yamaha generator.
Spec for spec the Yamaha meets the Honda 1000 in every category. The Yamaha 1000 has a bigger engine than the Honda 1000 and is extremely quiet under nearly full load. There is ZERO noticable difference in running on propane vs gasoline no matter what anyone says. On propane, with all the bells and whistles running, the Yamaha barely sipped propane. I would estimate at least 24 hours or more before emptying a 20lb tank at half and at times full load.
Old 10-13-2006, 04:53 AM   #18
peegreen's Avatar
I bought a Yamaha 2400 and the propane conversion kit from US Carb. I never did the conversion because I sold the generator. An adapter plate goes between the carb and the engine, no drilling, and allows you to still use gasoline as well as propane. I still have the conversion kit, but will probably return it or exchange it to fit my next generator.
WBCCI 24291
New England Unit
Old 10-13-2006, 08:35 AM   #19
2003 25' Safari
Eden Prairie , Minnesota
I have a Honda EU2000i and keep it in a large Rubbermaid container. No fumes problems - which is surprising because the Rubbermaid container is not really airtight. I do not bring a gas can... I just fill up the generator at the pump.
Dan
dmac is offline   Reply With Quote
Old 10-13-2006, 08:58 AM   #20
campadk's Avatar
2007 19' Bambi
Ottawa , Ontario
Is there room for a Honda or Yamaha 1000 in the back trunk of a new 19ft Bambi?
I vaguely recalling opening the trunk at the dealer, but don't remember the size. We won't have our AS for another week or so, so I can't check this out myself.
Isn't having a gas generator in a rubbermaid container dangerous if fumes build up inside?
I'm definately interested in the propane version mentioned. That would provide more options for transport.
Lots of great info as always!
campadk is offline   Reply With Quote
Old 10-13-2006, 10:24 AM   #21
_
hi campadk
most of the back hatches are tall enough to fit a generator...
and given that the most jiggling anywhere in the trailer is a the aft position, i wouldn't want mine there.
the honda gas gens have a gas cap that allows closing of the vent. infact IF you run the gen with the cap in 'closed position' it will stop after a few minutes and create a vacumn in the fuel line.
i've carried mine in a zip lock bag and inside a big rubbermaid. it doesn't really give off fumes that way.
IF i were carrying it inside the trailer, i'd do what jglabrown has done...container it and place just inside the door, on a non skid matt...last thing in and first thing out..this would result in virtually no fumes imo.
i've had mine inside the house contained and couldn't smell it....
as for size the 2000 will run everything in the trailer expect the a/c. the 1000 will not run microwave, water heater, convection oven, heat pumps, large blow dryers or bigger vacumns....or combos of these things...lights yes, battery charge yes but 900 watts isn't much juice these days...
in terms of space, price and utility the 2000s is at least twice the value of a 1000 for 20% more money.
another consideration is home backup use. i've used the 2000 for power outages and to run tools remotely and a variety of non airstream applications...
yes lpgas is cleaner and cool. but carrying an extra 20lbs of lp just to use the genset....isn't ideal. if you opt to run it from the a/s tanks the genset will always need to be near the front of the trailer. i can put mine anywhere...front, rear, side, behind a tree, the firewood and so on...
IF you are gonna get one buy a 2000...for 900$ after a season of use you will know IF you really want or need the lpg conversion. the honda 2000s are very easy to sell used...if you opt for a different model.
btw, i was inside several 75ths being built...all stages. yours may have be a shell then. i've got some observations about the unit for ya...i'll put them in your thread...
cheers
2air'
Old 10-13-2006, 11:17 AM   #22
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I converted my Honda EU200i to run on propane. On a long 4 day weekend I run it off the 33 gallon tank in the bed of my pickup. I also run it off of one of the 30# bottles on the Airstream. For storage, I place it inside the A/S. No worries with gas fumes. A friend has a gasoline powered EU2000i if we need to run the A/C. I have a home made cord set for running 2.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 10-13-2006, 01:15 PM   #23
jglabrown's Avatar
I agree with 2air. Also, since the aft hatch on the 16' is only a little over 11" in height and the 2000 Honda is 17+" high, the aft storage space is out for us. As I mentioned, no problems (so far) storing just inside the entrance door while traveling (and also when away from the camp site).
Pick, I really liked your post last year on the conversion. Tell me about the noise level before and after. (I hate to harp on it, but noise really concerns me when camping around others - don't want to be a bad neighbor)
Larry
"so far, so good"
Old 10-13-2006, 01:53 PM   #24
_
Originally Posted by 2airishuman
most of the back hatches are tall enough to fit a generator...2air'
of course this is supposed to read...
"most of the back hatches are NOT tall enough to fit a generator"
sorry for the poor proof read.....
larry...
keep in mind pick has propane tanks for fumigation of his diesel truck. so he's commited to propane for other reasons...
i've posted elsewhere on noise levels of the common generators....
have you read somewhere that noise levels change for converted units?
i don't understand how that would happen unless rpms are modified somehow.
the combustion chamber hasn't changed...
since lpg contains slightly less energy than gasoline,
i've read conversions reduce kwatts 5% or so...
i don't know if that is really true or if converted units run at a higher rpm for a given load...
which would increase noise but still be within the measured levels...
my understanding is that honda under rates their units true output...
so again conversion shouldn't limit generator capacity....
conversion is easy with the kits...i use mine so much away from tanks that carry the lp stuff would be a bother....
picnics, hiking, biking...the genset is just there ready to provide juice. a full tank of gasoline lasts 6-12 hours for me....
cheers
2air'
Old 10-27-2006, 09:05 AM   #25
campadk's Avatar
2007 19' Bambi
Ottawa , Ontario
I'm leaning towards a Honda EU2000i. If I store it inside the door of our Bambi as suggested, I'd be worried about it being knocked over... possibly. Shouldn't it somehow be secured in its place? Or is its 46lbs of weight going to do the job on a none slip mat?
Old 10-27-2006, 09:17 AM   #26
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Welcome!
Yes you see lots of Hondas and some Yamahas out there and they sure do come in handy. We went through the normal discussions of what brand and how big and finally decided all we really needed was something to top off the batteries when Boondocking. When we are out far away, we don't need TV, A/C or anything else other than a few lights, a fan or two and of course water and dump. Just when we were going to pick up our Honda 1000 from the local dealer before heading out to Yellowstone for thre weeks he raised his price. Well we ended up purchasing a Kipor. A little known brand used mostly by Fire Departments and EMT's. Saved several hundred dollars and very happy. Now the reason for this horribly long story is that we keep ours in the back of our Tahoe in a boot tray. It has a wonderful feature which I would imagine the Honda and Yamaha also have. There is a vent cap which when closed eliminates and evaporation or fumes coming from the gas tank. I took a turn a little sharp one morning (without the AS) and the Kipor fell over and no spill or smell. So when on the road we feel quite comfortable with it in the back! Of course we never carry fuel cans in the truck and we have found that we get plenty of run time with the fuel tank it has.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 10-27-2006, 10:08 AM   #27
campadk's Avatar
2007 19' Bambi
Ottawa , Ontario
Hmmm.. well considering we don't have a microwave, not worried about a/c since we are camping almost exclusively in the north, and the water heater runs on LP... maybe a 1000W genset will do. I'd anticipate we only need it to top up batteries mainly.
So I quess the question is what will a 2000W unit do for our situation that won't be satisfied with a 1000W unit?
Old 10-27-2006, 10:34 AM   #28
2003 25' Safari
Dave - I have the same situation as you and decided on the 2000 because:
- My wife likes to use an electric coffeemaker and electric hairdryer.
- It can power our furnace at home when we have a winter power outage.
- It can be used for power tools when too far from an outlet.
- I have the option of buying another 2000 and the paralleling kit to run the A/C.
When I use the gen to recharge the trailer battery, I simultaniously plug-in all other rechargable devices - razor, AA battery charger, laptop computer,etc. I don't know the total wattage, but it may be worth calculating before you decide.
The advantages of the 1000 are lighter weight and lower cost.
Dan
Portable Generator Marks Generators & Solar Power 38 11-04-2017 08:36 PM
Portable AC units ????? clancy_boy Furnaces, Heaters, Fireplaces & Air Conditioning 41 05-31-2017 05:39 PM
Replacing Onan for a portable generator Paul Daugherty Airstream Motorhome Forums 7 06-15-2012 08:43 AM
Portable heater suggestions ALANSD Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-22-2005 02:54 PM
Cleaning the portable water systems after use Silvertwinkie Fresh Water Systems 4 07-01-2003 03:46 PM
