Old 07-25-2010, 11:29 AM   #1
Frank&Mike's Avatar
2016 27' Flying Cloud
Georgetown , Texas
Portable Generator - Lockbox
I have been trying to find some kind of lockbox or method of securing our portable generator without success. So I am resorting to trying to come up with some concept/design that I can have a welder fabricate for us.
Attached is a simple drawing of the concept that I have come up with and can be explained as follows:
1. Lockbox is approximately 5 inches larger than the Portable Generator in all directrions.
2. Lockbox would be fabricated of a steel mesh type material on all 4 sides to allow plenty of ventilation all around the Portable Generator.
3. Lockbox would be fabricated with a solid steel material on top to prevent rain from getting on the Portable Generator.
4. Lockbox would be connected to a heavier steel base (reference "A" on the drawing) using a heavy duty piano hinge (reference "B" on the drawing).
5. Lockbox would be locked down to the heavier steel base with a simple heavy duty locking hinge.
6. Steel base (reference "A" on the drawing) would be approximately 24 inches longer than the Lockbox to allow a pickup tire or RV tire to drive onto the assemly as a means of securing the Lockbox and Portable Generator.
What are your thoughts? Do you think this concept would work to conceal and secure a Portable Generator appropriately? Or am I wasting my time and money?
I haven't been able to find any kind of cabinet online, at Lowes or at Home Depot that would provide the kind of security I'm looking for. Any input on this conept or available Lockboxes out there for sale is most appreciated.
Frank&Mike is offline   Reply With Quote
Old 07-25-2010, 11:32 AM   #2
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
We have a member of our unit who has a similar set up, just without the box. He installed a heavy piece of aluminum diamond plate to the bottom of hte generator and parks his trailer on the long end of the plate sticking past the generator. The box would probably be nice to keep the generator out of the weather.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
LHall is offline   Reply With Quote
Old 07-25-2010, 01:56 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Cable and lock? That is what we do with the ones at work.
I do like the idea of the plate and parking on it though..
Aaron
WBCCI #XXXX AIR #2495
Old 07-25-2010, 02:07 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
I like the idea...we know the similar set up that Louis mentions...works for him pretty well...and since he generator is actually attached to the plate, there are no locks to break/cut.
A couple of things to consider if you proceed:
(1) How are you planning to lock it? The box will be no more secure than the lock that locks it... If bolt cutters can cut a chain or cable, they can cut a padlock.
(2) Will the sides of the box be such that they will keep rain out if there's wind?
(3) Do you have room to haul it? For us this would be a problem, as space is limited.
Keep us posted!
TB & Greg and Abbey Schnauzer
#3954
Old 07-25-2010, 02:49 PM   #5
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
A couple of trips ago I saw a generator sat on the ground in the shade of a trailer, running happily and unmolested. Nobody would touch it.
It was bright pink, and written in sharpie on the top it said "I have cooties!" and on the four corners of its frame was written "STOLEN FROM [ZIP+4]"
I don't know how effective that is, but it made me laugh.
Your generator is small and has a molded handle. Can you bike-lock it to a tie-down or the frame?
TX-16
Dave Park is offline   Reply With Quote
Old 07-25-2010, 03:17 PM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I have an EU1000i that I use to charge the battery when needed. I lock it inside my truck at night.
Richard
Old 08-15-2010, 09:45 AM   #7
Frank&Mike's Avatar
Georgetown , Texas
Generator Lockbox
The Generator Lockbox is now completed. Attached are several of photos of the end product. To further disguise the contents, we plan to cover it with a plastic tablecloth (when not in use or when necessary to cover for rain) when the Generator is not running. The area that is painted black is where either the tow vehicle tire or RV tire will be driven onto the lockbox assembly as a means of securing it. In addition we will secure the unit and lockbox assemby to the axle of the tow vehicle or RV with a cable and lock. If someone is going to go to the effort to cut through all the assembly and cables then they can have it and we will file an insurance claim at that point.
ID:	108799   Click image for larger version
ID:	108801   Click image for larger version
Old 08-15-2010, 10:41 AM   #8
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
That is quite a lockbox. I doubt you will have any thieves who are that motivated. They tend to go for the quick and easy snatch. Nice work!
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
Old 08-15-2010, 11:30 AM   #9
Dave Park's Avatar
2005 22' Safari
The easiest way into that box is to cut out the top mesh with heavy duty wire cutters and lift the genny straight up. Three minutes and not much noise.
I'd put re-bar or something across the center of each panel, just to rule out that kind of "hack."
TX-16
Old 08-15-2010, 11:50 AM   #10
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
NICE JOB
Good ventilation,access to controls, design will deter most snatch and grabs.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 08-15-2010, 11:14 PM   #11
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Looks great, guys!
#3954
Old 08-16-2010, 06:35 AM   #12
Kevin245's Avatar
Great preventive measure and placing the hasp at the tire side is a good idea. Many thieves are opportunists and I would think most of them would pass yours by to look for an easier target.
For a cover you might consider contacting Kristi Foster or Silver Threads for some options. I recall Kristi making some specialty covers along with her awning biz.
Regards,
Kevin
Eleanor Roosevelt
Old 08-16-2010, 02:17 PM   #13
Frank&Mike's Avatar
Georgetown , Texas
Thanks all for the feedback and suggestions.
Old 02-02-2012, 10:34 AM   #14
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Evil thoughts
Turn the cage into an electric fence! ZAP! Would work while genset was running fo' sho' Fried thief.
Charge up a couple of batteries for when the genny isn't running? Practical or just too dangerous?
Proximity alarms anyone?
Paula
Portable Generator Marks Generators & Solar Power 38 11-04-2017 08:36 PM
Replacing Onan for a portable generator Paul Daugherty Airstream Motorhome Forums 7 06-15-2012 08:43 AM
Do you ground your portable generator? Chasmorgan Generators & Solar Power 16 08-04-2010 09:11 PM
Portable Generator transport 4arstrm Generators & Solar Power 29 10-30-2006 11:17 AM
