Old 10-14-2006, 05:25 PM   #15
Colo_StreamN's Avatar
2005 19' International CCD
Colorado Springs , Colorado
John,
I was thinking about that but I assume that when you use the dc output on the generator you get zero smart charging capability and you need to watch the batteries very closely? I'll go serarch for your earlier post.
Jerry
Colo_StreamN
K0JEH,
WBCCI # 5630
Pikes Peak, Colorado
FCU
TAC CO-1
Colo_StreamN is offline   Reply With Quote
Old 10-14-2006, 05:55 PM   #16
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Originally Posted by Colo_StreamN
John,
For a short period (couple of hours) you aren't going to do any harm to the batteries. After all, you tow all day with the tow vehicle putting a similar voltage on the batteries through the umbilical. Smart charging is only important for long term charging.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 10-14-2006, 05:57 PM   #17
Pahaska's Avatar
Hays County , Texas
My pervious post is in the thread
http://www.airforums.com/forum...ies-26916.html
John W. Irwin
WBCCI #9632
Old 10-14-2006, 06:57 PM   #18
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
John I posted a question about your direct charging of the batteries to the generator in the other thread. Thanks.
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 10-16-2006, 08:12 PM   #19
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I have 27.5 hrs. on a Yamaha 3000iSEB (500 watt additional boost when needed) which powers my 13,500 BTU DuoTherm Penguin A/C just fine. It's only drawback is it's 151 lb. heft. I have to have help lifting it into and out of the bed of my 2500hd pickup. I can load/unload it at home with the use of several long 2X8 wood ramps with aluminum ends but once at the campsite I have to have someone help me get it out. I've been looking for aluminum ramps that will fold up and fit in the 6.5 ft. pickup bed. For this reason, I recommend buying the Honda 2000 now for charging batteries and general lighting use through your converter then buying a second 2000 when the pain strikes you along with the parallel kit. That will give you 4000 watts and the running of the 2 generators is still very quiet. This seems to be the ticket now according to a number of other RV forums. If only Honda or Yamaha would make a 4000 watt unit weighing around 65-75 lbs. then that would be just right for me. Wishful thinking I guess.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Need advice on a portable 12V freezer Xray Refrigerators 9 03-29-2004 12:30 PM
Electric or Gas electric fridge replacement?? tin can luv Refrigerators 26 03-22-2004 09:50 AM
idle ?s about quality of space, life suspiria_2 Full-Timing 21 10-22-2003 06:53 PM
Thoughts on quality and prices ipso_facto Our Community 4 04-29-2003 08:04 PM
Electric Brake Question 68 Suburban Brakes & Brake Controllers 6 03-04-2003 08:09 PM
