Old 11-29-2011, 03:16 PM   #1
2012 23' FB International
Hollister , California
Plug & Play help
I,m basically an agnostic when it comes to practical matters: if I cant see it ,touch it, or feel it it doesnt exist. Never having seen an electron, electricity is some sort of hoax! So when I get to my question you"ll understand why I'm asking for straight forward "do this, then do that" sort of answer. Am contimplating getting one or a pair of generators...probably 2 Honda 2000s ( standard and companion). Want near 30 amps so I can use the ac and microwave. I know there's a wiring kit to couple the gens. Now once that's done is there a supplied cord that simply plugs into the 30 amp ac receptical on the side of my 25 Inter? Or what?
Luftnoggin is offline   Reply With Quote
Old 11-29-2011, 03:24 PM   #2
SteveH's Avatar
Common Sense , Texas
You use the cord from the trailer you normally plug into the pedestal at the RV park, and plug it into the generator after they are running.
Regards,
Steve
Old 11-29-2011, 03:27 PM   #3
2007 27' Safari FB SE
Wheat Ridge , Colorado
it would be the same cord that you plug use to plug into shore power at a camp site or your house. you may need to get an adapter for the cord so it will fit, I had to get one for my 3000 generator.
The Driver is offline   Reply With Quote
Old 11-29-2011, 03:29 PM   #4
Thanks, pretty straight forward.
Original trailer plug wiring diagram? edglenn Electrical - Systems, Generators, Batteries & Solar 15 05-04-2018 07:55 PM
New 30 amp plug needed ck21084 Batteries, Univolts, Converters & Inverters 21 09-29-2016 11:42 AM
What kind of plug terminal is this? bookem666 Electrical - Systems, Generators, Batteries & Solar 3 08-02-2011 08:14 PM
Wet weekend in our Safari OR How I discovered the Blow Out Plug! Brow324 Plumbing - Systems & Fixtures 16 04-18-2011 11:15 AM
