Old 07-22-2007, 03:33 PM   #1
MrAgent007's Avatar
2006 22' International CCD
Hershey , Pennsylvania
Images: 21
Permanent Mounted Generator In 22 CCD
Hello, Has anyone had either a gas or diesel generator permanently mounted to their Airstream RV trailer. If so, what size, where was it mounted, where is the source of fuel and who was the manufacturer? In addition, was this a "professional" installation by a RV specialty type shop? Thanks for any information. I am thinking about having an Onan 3500 Watt generator installed in my 2006 22 CCD.
Alex
MrAgent007 is offline   Reply With Quote
Old 07-22-2007, 05:30 PM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
OK, I'll bite - WHERE? I have an '03 CCD 22 foot and am pressed to see where you would put one. Just wondering, kinda made me go out and look at mine for a while......
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 07-22-2007, 06:33 PM   #3
MrAgent007's Avatar
Images: 21
Generator Location
I am leading to mounting the Onan 4000 which weights 200 lbs behind the propane tanks. As a result, I will need to re-locate the battery box. The Onan has a width of 18 inches and is 14 inches high. 30 inches is the length. Looks like I could frame mount it just behind the propane tanks.
Alex
Old 07-22-2007, 06:55 PM   #4
bobkelly's Avatar
Whittier, California , Depoe Bay, Oregon
I'm interested in any info available, also. I'm looking smaller, 1000 or 2000w Honda. Maybe over the battery box and powered by the adjacent propane?
2003 22ft CCD Int'l
2005 GMC Yukon Denali
WBCCI #2960
bobkelly is offline   Reply With Quote
Old 07-22-2007, 07:05 PM   #5
_
200 additional lbs on a 22 ft frame tongue? i don't like that idea.
here is a member link to mounting a honda 3000 (140lbs?) on the tongue...
http://www.airforums.com/forums/f448...ion-30513.html
and a warning about doing this...
http://www.airforums.com/forums/f48/...ting-4889.html
we've also had a member report his experience with photos...
mounting 2 honda eu 2000i on a self made rack in this location...
with the parallel kit this would be under 100lbs...
but you'll have to find that thread...
cheers
2air'
Old 07-22-2007, 10:32 PM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, Bob. I have had the same idea of mounting a Honda 2000 over the battery box and connected to propane.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-23-2007, 02:56 AM   #7
MrAgent007's Avatar
Images: 21
Tongue Weight
Actually the 2800 watt, 23.5 amp Onan unit weights 113 lbs. The 3600 watt, 30 amp Onan weights 175 lbs.
Alex
Old 07-23-2007, 07:09 AM   #8
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
I have seen one
I seen an Onan mounted in a 32 foot excella. It was placed (from the outside) inside of the credenza, a much deeper credenza than most. Anyway, this Onan was insulated and exhausted to the exterior, The guy had a genturi that he had permanently attached. He had transfer switch too.
It was a great setup! The guy had traveled to AK twice with this rig from the east coast.
smily is offline   Reply With Quote
Old 07-23-2007, 07:36 AM   #9
2005 30' Classic
Images: 12
I have a Onan Micro-light that I installed under the gaucho in my '66 22 foot Safari, just behind the streetside wheel. It's fuel comes from the propane lines. It is quiet and care free.
It has a strong lung, giving 3 kw of continuous power, which is enough for a small air conditioner.
You can view pictures of it in my photo gallery.
GetOutDoors is offline   Reply With Quote
Old 07-23-2007, 09:35 PM   #10
1985 34' Excella
McKinney , Texas
Send a message via Skype™ to dwlee6
Permanent generator
I mounted a 5KW Onan Marquis in my 1985 34' Excella. I put it under the forward dinette seat on the curb side. The Marquis exhausts and draws air through the floor (by design.) The outside dimensions of the Marquis mounting pan are almost exactly 1/4" smaller than the inside length/width of the dinette seat box. I had to add 2" height to the the seat by adding oak strips to the original box. I also created a galvanized steel liner for the box for fire resistance. Put sound deadener as described elsewhere in this forum on inside of box. Very quite, you more feel it than hear it, and with AC on, can't really hear the gen.
For fuel, I fabricated a 26 Gallon stainless steel tank that rides between the propane tanks and the front of the trailer. Photos attached of gas tank. Don't have any of the gen installation, but if you look closely at the side view of the trailer you can see the exhaust pipe sticking out the bottom of the trailer about half way between the step and the right side front tire. Aside from this and the slightly higher dinette seat, you can't tell there is a generator in the trailer.
In case you are wondering about all the weight, notice on the right side view of the gas tank the 3" tubing welded to the A frame under the original frame. I did this to the frame all the way back to the mounting point for the axles, giving a 2"x9" cross section frame on the front half of the trailer. Originally did this because the heavy duty tow vehicle ('97 one ton diesel Ford van) was causing the frame to flex (this all before the generator and gas tank installation) and cracking the aluminum skin at the corners of the battery access doors. It was quite a project, requiring removing the skirting and peeling back the belly pans to get access to the frame. No flexure now! The van and Pull rite hitch handle the weight with no problem.
Name:	side trailer.JPG
ID:	41801   Click image for larger version
Name:	ls gas tank.JPG
Name:	rs gas tank.JPG
ID:	41803   Click image for larger version
Name:	close up gas tank.JPG
dwlee6 is offline   Reply With Quote
Old 07-23-2007, 10:31 PM   #11
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Wow, I'm impressed!
SuEllyn & Brian McCabe
Old 07-24-2007, 07:56 AM   #12
bobkelly's Avatar
Thanks for the ideas. Slick, very slick. Welcome to the forums.
2003 22ft CCD Int'l
WBCCI #2960
Old 07-24-2007, 09:01 AM   #13
DayStreamer
grizzy's Avatar
2001 19' Bambi
Mesa , Arizona
Two Hondas on a Bambi
This link is to my experience mounting two Honda EU2000i's on our Bambi. http://www.airforums.com/forums/f198...tml#post114671 We've used this for some time now (with a couple of modifications) and have been very happy with the result.
Dave
DayStreamer
2001 19' Bambi
02 Avalanche
Mesa Arizona
AIR #5591
grizzy is offline   Reply With Quote
Old 07-24-2007, 09:59 AM   #14
2005 30' Classic
Images: 12
I found that my Onan generator was short enough to fit under the original seating (which I used as a measurement to build a new gaucho seat/framework). I also determined that it fit well where the original tool access panel used to be, providing adequate access from outside.
I would highly recommend this kind of install: you don't have to worry about the generator being exposed to the outside elements, including theft.
Also, if you convert the carb. to run on propane, it becomes more trouble-free, as the carb. burns much cleaner . . .
ID:	41828   Click image for larger version
2003 CCD International J Goertzen 2002 - 2005 International 3 08-20-2007 02:46 PM
2003 International CCD Pahaska 2002 - 2005 International 5 10-27-2006 10:37 PM
CCD 2nd excursion ChrisAich 2002 - 2005 International 18 07-29-2003 04:34 PM
Buying a CCD Ed L 2002 - 2005 International 30 04-21-2003 03:14 PM
The CCD vs the AS Pahaska Our Community 2 06-11-2002 03:47 PM
