Old 08-02-2007, 08:01 PM   #15
MrAgent007's Avatar
2006 22' International CCD
Hershey , Pennsylvania
Images: 21
Very Nice! Thanks.
Alex
MrAgent007 is offline   Reply With Quote
Old 06-11-2011, 08:26 AM   #16
Denis4x4's Avatar
Durango , Colorado
Knocked this out in an afternoon using some scrap wood. I do have a cover that I use. I'm a big fan of the Master cable lock to keep things from getting legs.
ID:	132169   Click image for larger version
Denis4x4 is offline   Reply With Quote
Old 06-11-2011, 10:38 AM   #17
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
eu3000i on tongue
see this thread for my mod mounting a honda 3000 elect start model on the tongue of my 85. I have since sold said 85 and purchased a 95 and have made the same mod to it. http://www.airforums.com/forums/f448...tor-54172.html Again, if you are specifically interested, email for more info. bill Oh, I tow with a one ton Ford van-have had no troubles with any kind of flex. for the record (in case you don't look up the thread) I removed the spare tire and carrier from under the A/S as well as the tongue mounted "tool" box and replaced it with an 11 gallon fuel cell for extra fuel capacity. AS of today, using a set of Longacre Racing scale pads I have (added on edit-dang if I know where the rest of my note went?) less than 700 lbs on the tongue. More on this later.
wmarsha is offline   Reply With Quote
Old 06-11-2011, 02:45 PM   #18
Western slope , Colorado
Looks like it would be hard to reach the pull/start cord!
"If you come to a fork in the road, take it."
Yogi Berra
Streamside is offline   Reply With Quote
Old 06-11-2011, 06:38 PM   #19
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I think Denis4x4 uses this for carrying purposes only, but we'll let him tell us. Looks like the mount has to be removed to open the battery box door? I think, I will make something similar to your bracket for a portable wheeled dolly for my Yamaha.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-11-2011, 10:14 PM   #20
Denis4x4's Avatar
Durango , Colorado
Correct, it's designed to carry the Honda. Note the bevel on the wood so that the battery door can be fully opened.
Old 06-12-2011, 03:34 AM   #21
UAPachyderm's Avatar
2004 28' International CCD
Birmingham , Alabama
Denis4x4, that's simple and smart! Well done.
UAPachyderm is offline   Reply With Quote
Old 06-12-2011, 07:02 AM   #22
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
That is similar to what I did. But I used aluminum stock and extended it so the weight is supported by the sides of the battery box and not just the cover. I can open the battery box about half way but need to remove the lp tank cover to open it fully. I tie it all down with nylon straps that wrap through the gen handle and around the battery box. A bike lock adds some security.
2012 Dodge Durango Hemi/AWD
Old 06-12-2011, 07:16 AM   #23
Wayne&Sam's Avatar
Images: 21
Here's what it looks like.
Old 06-12-2011, 07:39 AM   #24
Is your Gen a 1000 or do you just have more space between the tanks and A/S?
Old 09-03-2011, 02:15 PM   #25
Wayne&Sam's Avatar
Images: 21
Sorry, I've been out 'streaming. It's a 1,000. I have a 2,000, but I think the fit is too tight. It fit, but I'd be banging up the AS taking it in and out.
Old 09-03-2011, 09:16 PM   #26
2011 23' FB International
1975 Argosy 30
Santa Barbara , California
I have a Yamaha 2000i that fits the same space on a 2010 23FB. It adds weight to the tongue, but I don't know where else to put the thing. In the SUV it's mostly OK, but does fume a bit when it gets hot or climbing altitude.
tvoneicken is offline   Reply With Quote
Old 09-04-2011, 10:50 AM   #27
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
Is the Yamaha 2 kW narrower than the Honda 2 kW?
A Blog from the Devil's Triangle
http://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
2003 CCD International J Goertzen 2002 - 2005 International 3 08-20-2007 03:46 PM
2003 International CCD Pahaska 2002 - 2005 International 5 10-27-2006 11:37 PM
CCD 2nd excursion ChrisAich 2002 - 2005 International 18 07-29-2003 05:34 PM
Buying a CCD Ed L 2002 - 2005 International 30 04-21-2003 04:14 PM
The CCD vs the AS Pahaska Our Community 2 06-11-2002 04:47 PM
