Old 08-01-2010, 09:02 PM   #1
1973 31' Sovereign
Auburn , New York
Onan won't stay running
Just bought a '73 31' Sovereign. Onan "battery charger" wont stay running. Original, and not sure the last time it was run. Got it running by holding the fuel solenoid and using the pull start, but once i let go of the button, dead. The book says that the fuel solenoid will stay running if it is getting a charge. Just wondering if there is anything I could try before pulling it out and bench testing. Thanks
Nysup is offline   Reply With Quote
Old 08-23-2010, 09:16 PM   #2
lucca53
lucca53's Avatar
1973 31' Excella 500
2004 22' Safari
2006 25' Safari
napa , California
I also have one in my 73 excella which does not work and i have no manual what so ever,not sure if ill fix it or just take it out and use space for something else?
lucca53 is offline   Reply With Quote
Old 08-23-2010, 10:08 PM   #3
Now both of you know why Airstream shelved that generator project.
Everytime you change altitude, even as little as 1000 feet, the carb had to be readjusted.
It's just another one of those "great" ideas, that just didn't pan out.
No one that I know of, has ever come up with a permanent fix, not even Onan.
Old 08-23-2010, 10:46 PM   #4
x
XXXX , XXXX
Hi guys If you PM me your e-mail I will send you a copy of the owners manual I have
wasagachris is offline   Reply With Quote
battery charger, generator, onan
89 Onan 6.5 Generator MSarif Generators & Solar Power 5 10-25-2012 01:35 AM
Onan running but no power to a/c.... mossyoaks Electrical - Systems, Generators, Batteries & Solar 4 09-06-2010 08:29 PM
Onan Retro fit Sundance Electrical - Systems, Generators, Batteries & Solar 4 03-25-2007 07:42 PM
Refer Won't Stay Running on LP wbcci3371 Refrigerators 3 05-20-2004 12:14 AM
