Old 06-15-2009, 09:35 AM   #1
Dr.Theopolis's Avatar
1977 24' Argosy 24
St. Augustine , Florida
Onan smokes under load
I have a 1977 Onan BF model 4kw gas generator which I have been fixing up. I finally got it running smooth. When I hook up a light electrical load, it runs ok. When a bigger load is applie, the engine seems to bog down and smoke come out the tail pipe. The smoke is a light color (not black). I have the service manual but this problem is not directly addressed in it. Has anyone seen this exact problem before and know what the problem is?
Dr.Theopolis is offline   Reply With Quote
Old 06-15-2009, 09:40 AM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
By bogging down do you mean you lose rpm? How does the voltage and frequency look? light in color? Do you mean Blue? that would be oil.
Black too much fuel. air cooled or liquid? White color would be coolant.
Michelle TAC MT-0
Sarah, Snowball
Old 06-15-2009, 09:55 AM   #3
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Anything electrical, or internal combustion has smoke inside.
If the smoke comes out, they need attention, or will usually stop operating.
Never let the smoke out.
Old 06-15-2009, 10:10 AM   #4
Pop Rivet's Avatar
1990 25' Airstream 250
Altoona , Georgia
1977 - It's my guess that the thing is just flat worn out and not worth the cost of repair. A very dirty air intake might be responsible but it sounds like you have addressed that sort of problem.
Cummings owns Onan and for around $50? a Cummings/Onana dealer could troubleshoot it for you. I would not use a RV dealership.
Consider replacing it with a new unit. Night and day improvement
Pop Rivet is offline   Reply With Quote
Old 06-15-2009, 10:11 AM   #5
Pop Rivet's Avatar
Altoona , Georgia
I like it
Old 06-15-2009, 01:44 PM   #6
345bill's Avatar
Las Vegas , Nevada
Never let the smoke out.[/quote]
What is it's due to coughing?
345bill is offline   Reply With Quote
Old 06-15-2009, 03:33 PM   #7
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
I worked on tugboats for years and we always "exercised" the gen set once a week. I still do with Bess. The smoke is prolly piston rings staying in the jugs in the same position for too long.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 06-15-2009, 10:15 PM   #8
Keymar , Maryland
I had a problem not unlike that when I started a generator that had been in storage for three years. I filled the cylinder with oil when I stored it. all the oil was gone. I got it started and ran it hard for a couple of hours. the smoke stopped.
Michelle TAC MT-0
Sarah, Snowball
Old 06-15-2009, 11:24 PM   #9
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Tune-up and decarbonize.
Hi, check the air filter, adjust the carburetor, replace the spark plugs, and/or remove the heads to remove carbon build-up. Your owner's manual will tell you how to do this, or take it to an Onan dealer as previously stated, not an RV dealer.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-02-2009, 05:01 AM   #10
Pop Rivet's Avatar
Altoona , Georgia
Talking Solution
So - - - What was the fix? Shoot it with a 44 and install a Honda?
Old 08-02-2009, 08:45 AM   #11
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I missed this thread the first time around... If it turns out the smoke was oil, an interim fix is to drain the dino oil and put Mobil 1 in it. It will still use oil, but will no longer smoke. Even at $6 a quart, it will take a long time to equal the cost of a new generator.
Old 08-09-2009, 10:15 AM   #12
1977 24' Argosy 24
The fix was - sell it and buy a Honda
And I did! I finally had to get rid of it quick so I sold it for $150.
I now have a Honda eu2000ia and it is a challenge to make sure all my loads stay under 1600w but it is not impossible. I live on a boat and am very used to shutting X off so I can run Y.
With such a low power genny, I needed a lower power (and new/working) rooftop air conditioner - so I got an 8000btu which apparently has a nice starting circuit designed into it because it starts on the Honda very easily...even with the eco throttle turned on! I also replaced the perfectly working 65A Univolt with a 30A Intelli-power converter. Yes, the univolt is for sale in case there is a museum that wants it.
1/2 ton tires- load C to load E John Tires 75 03-20-2009 09:15 AM
Onan 6.5, Load Question 345bill General Motorhome Topics 6 02-08-2009 09:22 AM
Lighten Your Load davidz71 On The Road... 24 08-04-2008 07:28 AM
How not to load a vehicle dpandorf Tow Vehicles 11 06-28-2007 07:45 AM
Snow Load Navigator Winterizing, Storage, Carports & Covers 54 02-03-2007 02:13 PM
