Old 04-18-2011, 03:26 PM   #1
2005 30' Classic
Images: 12
Onan install – ’05 30’ Classic
I am installing a LP 2500 Micro-light in my 2005 30 foot Classic. If interested, go http://www.cumminsonan.com/rv/products/propane for specifications.
This is the second Micro-light I have installed: the first was installed in my ’66 Safari which I rebuilt from the frame up (and sold last fall). Pictures of that install can be found in my uploaded images (photo gallery).
Before beginning, I needed answers to the following issues/questions:
1) Can the LP 2500 run the 13.5K BTU air conditioner?
2) Where should the unit be installed?
3) Is the structure (frame, etc.) such that it can be installed without conflict?
4) Can I get the LP line ran to the generator?
5) Is there adequate 12 volt power available to that site (for auto-start)?
6) What access is there to the shore power and how hard is it going to be to install the transfer switch?
7) Is there a logical place close by to install the external control switch?
So far I have the transfer switch installed, the floor/structure work mostly complete (thanks to a productive weekend), the generator bolted to the floor, and the propane fitting that spans the sub-floor installed.
I still am trying to determine the best solution getting the LP line past the holding tanks (issue 4 above), and need to locate the main 12 volt source to the back of the trailer (issue 5).
I plan on posting a lot of pictures … please be patient. If there is something you really need to see and I haven’t posted, I’ll do my best: some things you just can’t get a visual once you progress past it.
So here, the adventure begins …
ID:	127411   Click image for larger version
GetOutDoors is offline   Reply With Quote
Old 04-18-2011, 03:58 PM   #2
withidl's Avatar
2002 31' Classic
Houston , Texas
2002 ASCL 31' With Built-in Onan Microquiet 4000
I have title built in gasoline powered genset. Go the the following link (page #2 and page #4) and read the entire post for details and complete photos of installation which may be of some help/comparison in your project:
http://www.airforums.com/forums/f448...ors-68808.html
withidl is offline   Reply With Quote
Old 04-18-2011, 04:00 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Sometimes but not on hot days at altitude especially as the generator gets older
Not sure but I myself wouldn't want it under the bed without a firewall.
There is no "main line" to the rear of the trailer, just lines for individual loads, since the 12v breakers are all in front under the gaucho. You can probably get away with 6 gauge boat cable and run it with the propane. Use a suitable sized fuse or breaker.
Not sure how it is with a queen but with a twin there's a panel in the rear outside compartment you can open.
Keep the photos coming. Not sure this project is for me but I'll still be interested to see what you put together.
Old 04-18-2011, 06:15 PM   #4
2005 30' Classic
Images: 12
That is part of the plan: not only does the firebox serve as a means to provide fire protection, but it also provides the means to "sound proof" the generator. If you look into my photo gallery, you can see the fire box and proofing I used in my last install.
Old 04-18-2011, 06:33 PM   #5
2005 30' Classic
Images: 12
Using the metal floorplate I created, I cut away the carpet where I wanted to install the generator to expose the sub-floor. I then used my stud finder, in steel stud mode, to locate the cross-member. My findings forced me to move the generator rearward about 2 inches.
The stud finder went nuts throughout the entire location, so I decided to drill a 1/8 inch hole using a drill bit thats about 15 inches long, and go under the trailer to cut away part of the belly pan to see what was going on.
The picture show you what I found: a big wide piece of metal welded between the cross members going down the middle of the RV.
This created a problem, because though the template I made offset the oil plug (which is located on the bottom side of the generator), the iron was still in the way.
Not wanting to reduce the support this iron provided, I came up with a work-around ... See the second and third pictures ...
ID:	127478   Click image for larger version
Old 04-18-2011, 06:40 PM   #6
2005 30' Classic
Images: 12
Progress picture ....
ID:	127485   Click image for larger version
ID:	127487   Click image for larger version
Old 04-18-2011, 07:44 PM   #7
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Looks like a nice installation. I had a similiar unit in my motorhome and it got pretty warm when running a while. What is your solution for cooling?
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 04-18-2011, 08:03 PM   #8
2005 30' Classic
Images: 12
Cooling, venting, and exhaust will occur through the floor. The air under the trailer should be the coolest around the trailer.
The exhaust will be piped away toward the side.
Old 04-18-2011, 08:20 PM   #9
moderator
Airslide's Avatar
Wilton , California
Images: 50
Does the manufacture give a specification on venting? Maybe there's a way you can monitor the temp of that box?
Old 04-18-2011, 08:34 PM   #10
2005 30' Classic
Images: 12
They do.
My buddy is an Onan engineer. The template shown in one of the earlier pictures was traced from his shop. Onan has specific installation requirements to properly cool the unit. In addition to the specifications link provided earlier, I'll provide a picture with containment parameters tomorrow. Without proper square inch venting the unit will not cool properly.
Old 04-18-2011, 09:11 PM   #11
moderator
Airslide's Avatar
Wilton , California
Images: 50
Sounds great.. keep us posted.
Vinnie
Old 09-08-2012, 08:16 PM   #12
2005 30' Classic
Images: 12
Here is the footprint of the gen (Bottom of the fire box).
Old 09-08-2012, 08:32 PM   #13
2005 30' Classic
Images: 12
Pictures of the install ...
ID:	167785   Click image for larger version
Old 09-08-2012, 08:34 PM   #14
2005 30' Classic
Images: 12
Views from the underside ...
ID:	167792   Click image for larger version
AirRowan, Duramax install for Classic Power John H. Classic Motorhomes 48 07-19-2012 09:32 AM
Sliding tray in A/S Classic bumper Ramblinboy Exterior Storage Compartments & Access Doors 17 10-20-2011 10:43 AM
Classic vs Classic limited Flying Gypsies 2006 - 2010 Classic (all lengths) 13 10-15-2011 06:37 PM
2008 Classic 25 with Ford '01 Expedition aggie71 Tow Vehicles 16 05-09-2011 03:15 PM
Classic Airstream Motor Home T-shirt and gift items maltnhops Classic Motorhomes 0 03-18-2011 11:10 PM
