Old 05-07-2011, 03:48 PM   #1
1973 31' Sovereign
Auburn , New York
Onan help!
I am finally getting around to figuring out this Onan (model 0.3 TL -212R 1973 Sovereign). I can keep it running if I hold the primer on, so I figure it might be a bad fuel solenoid. While tracing wires I found a horribly corroded wire seemingly pressed into a piece of aluminum. What is this and how do I replace it?
Nysup is offline   Reply With Quote
Old 05-07-2011, 04:25 PM   #2
1973 31' Sovereign
Auburn , New York
Found an old onan operators manual. The wire connects to a silicon rectifier. Thanks...got the answer.
Old 05-07-2011, 04:28 PM   #3
x
XXXX , XXXX
Onan Manual
I can't answer your question but this manual may help.
OnanTL12v.generator.pdf
wasagachris is offline   Reply With Quote
Old 05-07-2011, 06:51 PM   #4
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
I get parts for my old 74 onan gas generator from the the Cummins shop. So far they have had everything that I have needed.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 05-07-2011, 07:06 PM   #5
x
XXXX , XXXX
Daniel I also checked with Onan and most of the parts are now obsolete for this rare model. The motor is actually a Tecumseth small engine called a LAV-30 and Tecumseth is now out of business so most of their parts and made from unobtainium.
Onan does have some common parts but most are obsoleted and even their vendor of obsolete parts does not have them. I spent quite a bit of time surfing and calling looking for parts but gave up once I bought a function unit from another forum member.
Onan install – ’05 30’ Classic GetOutDoors Generators & Solar Power 16 09-10-2012 06:59 AM
Any 34' Limiteds w/generator? setblaster Trailer Values 15 04-15-2011 10:49 PM
L@K Airstream Mercedes Diesel Westfalia RV Class B OnaN SL@K Airstream Mercedes Diese eBay Watch Airstreams on eBay 0 03-28-2011 01:00 PM
