Old 06-20-2006, 08:06 PM   #1
JBK
JBK's Avatar
1986 34.5' Airstream 345
Grand Rapids , Up in the Nort' Woods of Minn.
Onan 6500 gen set problem
The generator won't start. It was touchy and needed to be jumped for a while but won't start now. The solenoid clicks, but it won't even turn over. I understand it doesn't have a starter. (I could be wrong, just what I was told and I can't see one.)
What do I do?
JB
JBK is offline   Reply With Quote
Old 06-24-2006, 11:32 PM   #2
Mopar Madness
Jefferson , Georgia
I just took my '82 6.5 kW to an Onan service center (to find out where the reset button was!) and in the process learned a little about how they work. You are correct, it doesn't have a starter per se. As I understand it, it starts by way of an internal electric motor (commutator) that spins the gas motor up to starting speed. It is separate from the electric motor that makes power.
You probably already have, but if it's like mine, check the two fuse links on the front panel. The tech told me that's the first place to check. Other problems can be the solenoid , fuel delivery, plugd, basically anything that causes small motors not to run or to run poorly. Seems like I did a seach of this site using "generator" and someone had posted the troubleshooting section from the AS motorhome manual. That might help.
Another forum that might be useful is a small engine forum I found that has several posts about Onans as well as a guy on the site who is an expert with them. If you sign up and post the specifics there, it looks like the responses are very technical and useful. http://www.perr.com/forum/
Good Luck!
Walt
WaltL is offline   Reply With Quote
Bad Problem w/ Water Pipe rroessler Fresh Water Systems 20 06-05-2006 11:23 AM
LP Regulator PatCrusse LP Gas, Piping, Tanks & Regulators 27 05-15-2004 01:22 AM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 08:21 PM
Hitch problem wyhjr Hitches, Couplers & Balls 8 07-22-2002 05:29 PM
Skylight - WARNING - possible Problem apple 1 Roof Vents, Skylights & Fans 0 03-24-2002 09:16 AM
