Old 06-22-2011, 06:26 AM   #1
1989 29' Excella
MontrealWest , Quebec
No parallel port...
I just bought a honda eu200i generator in Canada, and contrary to what is wriiten in forums, it doesn't have the parallel port connector. The vendor also told me it wasn't available for this model. Is there a difference between Canadian and American models? Thanks.
Ludovicus is offline   Reply With Quote
Old 06-22-2011, 09:39 AM   #2
Snedwid's Avatar
2011 23' FB Flying Cloud
Perry , Florida
I think: there are 2 different Honda 2000i gen. One is called 2000i companion, and it has a 30 amp outlet. This outlet is not the same config as the 30 rv cord on my AS, so an adapter is needed to interface the cord to the gen. Then the parallel cords hook the 2 gen sets together with 2 plug ins and a screw attached ground wire. Don't ask me why they didn't make the ground wire a plug in also.
"If you don't know where you are going, you will wind up somewhere else." Yogi Berra
Snedwid is offline   Reply With Quote
Old 06-22-2011, 10:01 AM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Interesting... on the Honda Power Equipment site they only show 2 basic configurations of the EU2000i, one that's the base unit with only 20A 120v outlets and the parallel operation outlets and one that's the "Companion" designed to run parallel with a base unit and includes the 30A receptacle.
Mind you, they show 4 distinct model numbers for EACH of the regular and companion units, and I'm not counting the "camo" version of the base unit. (Camo? Really? They're not THAT quiet.)
What does the front panel look like? Can you post a photo?
On a related side note, I found something I didn't know existed... there's a kit to allow you to connect 2 "regular" EU2000i units together, so you don't have to have the Companion model for one of them, and there's a version of the kit with a 30A TT receptacle. It's the 2nd photo, "EU2000i Parallel Receptacle Kits"
— David
Old 06-22-2011, 10:15 AM   #4
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Can you provide a picture of the front of the Generator?
Michelle TAC MT-0
Sarah, Snowball
Old 06-22-2011, 01:55 PM   #5
1989 29' Excella
On my Honda 2000i where the parallel port used to be is now a big void...Is the 12 volts battery recharging output a new addition to the 2000i instead of the parallel port? Now trying to attach a picture...
Old 06-22-2011, 02:08 PM   #6
DKB_SATX's Avatar
1976 Argosy 28
I wonder if the OP's latest post was deleted?
Anyway, looking at the pictures, I note one thing I've never seen before on one of these, the "Cold Climate Technology" sticker on the case. I guess one of the 4 distinct models Honda lists without detailing the differences is designed for cold climates, perhaps Honda thinks that means people there would never need more than 16A?
The ones I see in Texas definitely don't say anything about "cold climate" on them, and so far every one I've seen besides the photos Ludovicus posted here have the parallel operation ports.
PS: I found that the "regular" EU2000i generators have issues with carb icing in very cold temperatures that leads to surging and other undesirable operational characteristics. They're pulling in moist crankcase air and mixing it with sub-freezing incoming air and the moisture condenses and freezes in the carb. So, I guess the Cold-Climate version is doing something about that, but I've no idea why they eliminate the parallel option in the bargain.
— David
Old 06-22-2011, 02:19 PM   #7
alclad's Avatar
1961 16' Bambi
Wilmington , DE
Images: 46
interesting.... i found this--maybe it will help....
Woodalls Open Roads Forum: Tech Issues: Dual Honda 2000's in canada?
alclad is offline   Reply With Quote
Old 06-22-2011, 02:42 PM   #8
1989 29' Excella
I had problem attaching a picture so, as you guess my first reply was deleted.I still don't know how to attach 2 or more pictures together ... but with practice...There the link to the picture showing the "Cold Climate" thing...Thanks to all. Well as you know the need for A/C is much less up North...http://www.airforums.com/attachments..._2000i_001.jpg
Old 06-22-2011, 02:51 PM   #9
DKB_SATX's Avatar
1976 Argosy 28
So from those comments, it would seem that the parallel gadget doesn't like having neutral and ground bonded, which is required in Canada, and the cold-climate thing is unrelated. Innnnnteresting.
— David
Old 06-22-2011, 06:12 PM   #10
Keymar , Maryland
Well that does not look any version sold in the USA.
I went to Honda.ca. You do not have the parallel port on the Canadian version. Probably a regulatory issue.
Michelle TAC MT-0
Sarah, Snowball
Honda Generator Ramp Up henw Generators & Solar Power 7 04-17-2011 04:10 PM
Curbside vs Streetside Michigander Airstream Trailer Forums 34 03-26-2011 04:40 AM
Only one battery charging heslinhotel Batteries, Univolts, Converters & Inverters 11 02-21-2011 08:49 PM
