Old 09-30-2013, 11:36 AM   #1
Chasmorgan's Avatar
1999 23' Safari
No 12 volt on Generator?
110 appliances work but no interior lights. Battery supposedly new! Is a charged battery needed to run interior lights when on generator power or shore power? Trailer at a remote location so cannot test on shore power? All fuses and breaker ok. Thanks for your help!
Charlie M
TAC TX-6
Chasmorgan is offline   Reply With Quote
Old 09-30-2013, 12:03 PM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
The battery needs to be in place and hooked up for the 12V systems to have power even when hooked to a shore power source. When hooked to shore power or a generator the converter (turns 110V into 12V )provides power to the battery and keeps it charged as you "use up" the amps stored in the battery. With a digital volt meter check the voltage on the "new" battery. A fully charged 12V battery should read close to 12.6 Volts. If the battery is fully charged and the shore power is plugged in it will read a 13-14 Volts. If those two things check out then look for blown fuses or a tripped 12V circuit breaker.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 09-30-2013, 01:41 PM   #3
Skater's Avatar
1995 30' Excella
Bowie , Maryland
And check that the converter is turned on. Look behind the curtain, curbside, near the front of the camper for an unmarked light switch (that's where it is in mine).
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
12 volt
