Old 10-17-2014, 03:30 PM   #57
Builder of Diesel Jeeps
westernjeep401's Avatar
2014 28' International
Sedona , Arizona
Originally Posted by TomS View Post
We have a Honda 3000ei in the bed of the truck, and it will run the 13.5k ac in Eco mode with no problems. Electric start and the big tank are two pluses. Definitely recommend vs the Handi.
Good to know. Honda definitely makes a solid product; you pretty-much know your dough bought a runner.
14 Serenity 28'
#5261
westernjeep401 is offline   Reply With Quote
Old 10-17-2014, 03:52 PM   #58
silverbp's Avatar
2014 25' FB Flying Cloud
LaMarque , Texas
Well it sounds like you have already gotten some very good info back. I just retired as well I also have a 2014 flying cloud and looked long and hard for which gen to get. The 3000 is a little short at running everything in your RV. You can make it work. But it was too heavy to lift in and out of that truck. I can do it now but not so sure about in 5 years. The two 2000,s are not heavy and together can run everything. They have a 30 amp outlet and I also got the larger gas tank. They will run a long time between refueling. So no getting up in the middle of the night. I think the two 2000,s is for sure the way to go here.
Sent from my iPhone using Airstream Forums silver bp
silverbp is offline   Reply With Quote
Old 10-17-2014, 05:46 PM   #59
2015 28' Flying Cloud
Melbourne Beach , Florida
You will need two Honda 2kw to run the A/C. The 2 Honda's will give you 27amps.
Kingsmen 33 is offline   Reply With Quote
Old 10-18-2014, 10:21 AM   #60
2011 23' Flying Cloud
Durango , Colorado
Originally Posted by AnnArborBob View Post
With respect to the point about the relative noise of one 3000 vs. two 2000's has anyone considered that if you are running the two 2000's you are almost certainly running your AC which in and of itself likely negates any advantage of a few less db's with the 3000?
Am I missing something here?
Yes, the neighbors.
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Old 10-18-2014, 10:48 AM   #61
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Originally Posted by JamuJoe View Post
Yes, the neighbors.
My point was that at a reasonable distance (i.e., the neighboring campsite) the ambient noise of the AC unit itself would probably negate the small reduction in noise between a single 3000 and two 2000s.
Bob Martel
WBCCI# 5766
Old 11-06-2014, 01:59 AM   #62
Adiredneck's Avatar
2014 27' FB Classic
Vicksburg , Mississippi
So, if I'm understanding the accumulated wisdom, the Honda 3000iS is *not* sufficient to run one of the 15000 BTU heat pumps on our A/S?
And Robert@Honda, can you link a 3000 and a 2000, or do they have to be equal outputs?
"Hot meals, cold beer, dry bed & flush toilet - everything I look for in a wilderness experience..."
Adiredneck is offline   Reply With Quote
Old 11-06-2014, 05:34 AM   #63
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
The EU3000 fails to work for *some* people it seems to start the compressor.
If you google this question RV.net forum threads details several people that describe years of good effective use ....and then also a number of people describe it that it failed to start the compressor
I have no clear idea why for some it works and others it appeared not to work...but perhaps various changes in environmental conditions or differences in particular 15k AC units tips the scales
Ymmv
PharmGeek is offline   Reply With Quote
Old 11-07-2014, 10:22 AM   #64
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The linking is for two similar capacity Honda generator sets (i.e. two 2000 units or two 3000 units). The challenge is the inrush current to start the compressor. The 3000iS Honda is rated 3000 watts max with a continous rating of 2800 watts.
Two 2000 Honda generator sets (EU2000i coupled with a EU 2000i Companion) can handle 4,000 watts maximum with a continuous rating of 3200 watts. That is why the two can support a single air conditioner where the 3000iS might not support it.
The marketing material claims supporting only the 13,500 BTU air conditioner which is typically the second one added to the AS trailer. But our two 2000 Honda generators, when coupled, can run the 15,000 BTU primary air conditioner .
Old 11-07-2014, 10:27 AM   #65
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Apparently per multiple posts on other forums (3 to be exact on I've read)I have heard of successful parallel of different Honda units (ie Honda 2000+3000) - I have no idea if this is a good idea - just thought I would share that from a recent read...
The internet said it - must be true....
Two adults, two kids - what to buy? Veik Our Community 25 04-17-2014 09:48 AM
Two 12V vs. two six volt batteries spat61 Land Yacht/Legacy Motorhomes 37 04-22-2010 11:50 PM
Two converters in less than two years? stowaways Full-Timing 14 02-09-2010 02:40 PM
Two plus two cello The Pet Forum 1 09-26-2006 02:00 PM
Two 6 volts or Two 12V series 27 LI Pets Electrical - Systems, Generators, Batteries & Solar 0 09-07-2006 06:06 PM
