Old 06-27-2010, 06:15 PM   #1
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
New Yamaha won't start-Oil
So finally got a Yamaha 2400is. Was putting in the oil when I noticed that oil was coming out the other side. I turned it on it's side to fill and was using a funnel to fill it checking very carefully to make sure to not overfill. Was putting in a second quart when I noticed a very large spot of oil and growing on the concrete. It was coming out the backside. Immediately righted her and began wipint it down. Oil continued to drip out the bottom. When I turned it right side up was able to drain out extra oil in the can. Then began the cleanup, took side panels off and have done a pretty good job cleaning out all traces of the oil in bottom and components look good and dry but she won't start. Any clues here?
Been cranking for a while.
RichHog is offline   Reply With Quote
Old 06-27-2010, 06:28 PM   #2
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
It doesn't want to be on it's side to fill the oil... not to mention, the dipstick/cap won't read the oil level properly...
You say SECOND quart?
I'm pretty sure the 2400 doesn't take even one full quart.
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 06-27-2010, 06:31 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Try starting it with the low oil sensor disconnected, if it fires. Shut it down quick and reconnect the sensor and try again, if no start the sensor is bad. I also have to do this with my Hondas in cold weather.
Aaron
WBCCI #XXXX AIR #2495
Old 06-27-2010, 06:39 PM   #4
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Well you said you put oil in it but how about gas?
Al - K4GLU is offline   Reply With Quote
Old 06-27-2010, 07:24 PM   #5
tpi
Trabuco Canyon , California
Second quart? My Yamaha 3000 takes less than one quart. Are you sure you put in the correct amount of oil?
I'd verify a perfect oil level, then if it doesn't start pull out the spark plug and check it. Perhaps the cylinder flooded with oil.
tpi is offline   Reply With Quote
Old 06-27-2010, 07:41 PM   #6
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
oil
Funny thing I was being very careful when filling to make sure I didn't spill any. Yes put about 3/4 a tank of gas. Cleaned out air filter, it was oily, took out spark plug and it was dry clean, looked into the cylinder with a flashlight looked dry. How do I disconnect the oil sensor? Haven't heard it fire yet or try to start.
Old 06-27-2010, 11:19 PM   #7
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, did you turn the gas valve on? Did you choke it? Did you turn the ignition switch on?
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-27-2010, 11:25 PM   #8
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Ok it started after about an hour and a half of just sitting. Probably the remaining oil had to dry out in the hot humid air. Had no problem running the 13.5 AC unit on full and with lights on. Yeah!
Old 06-28-2010, 06:05 AM   #9
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
I'm looking at a Yamaha 2400is and wondered how much it would run at once. I've got 11000 btu ac so I should be able to do the same. I like the idea of one generator vrs 2 and the weight is amazing! Keep is posted on how you like it.
blmitch5 is offline   Reply With Quote
Old 06-28-2010, 07:28 AM   #10
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
That's what I was thinking, why 2 when one will do. It had no problem running my 13.5 Carrier V at high cool and lights on in the trailer. Paid $1275 for it from PPL here in Houston. Spending 5 days in Yellowstone with no power at site so it will be a good breaking in to recharge battery.
Old 06-28-2010, 07:53 AM   #11
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Did you get an operation manual with it?
Ahab is offline   Reply With Quote
Old 06-28-2010, 11:14 PM   #12
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Yes, or the instruction manual, lots of icons stketches you have to interpret. REad it through 2 x before moving on to the oil gas phase. guess my turining it on its side to fil the ol wasn't a good thing
Old 06-28-2010, 11:33 PM   #13
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
Filling to the designated oil level is a pain. You have to keep putting a small amount in until you reach the full point.
wingfoot321 is offline   Reply With Quote
Old 06-29-2010, 08:43 AM   #14
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Wingfoot and the other "too much oil" have your answer. You must fill only to the fill line on the dipstick - I am traveling so don't have my manual, but the total is much less than a single quart, iirc.
Dump all the oil and begin again. Read the manual - it will give you the oil capacity (and the correct oil viscosity, which I think is 5w15 - but read the manual).
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Does the amount of engine oil increase with the addition of a larger oil cooler? Mr. D Mechanics Corner - Engines, Transmission & More... 5 03-07-2009 08:56 AM
Yamaha Remote Start Question craftsman Generators & Solar Power 0 05-04-2008 12:07 PM
Yamaha EF4500ise Happycampers Generators & Solar Power 11 03-18-2008 09:09 PM
Yamaha EF2800i bhayden Generators & Solar Power 13 12-23-2006 01:46 PM
Yamaha Generators Bilouie Generators & Solar Power 27 04-23-2006 04:14 PM
