Old 08-11-2016, 05:26 PM   #1
DarrellT's Avatar
Longview , Texas
Neutral-ground in Honda & Yamaha gennies?
Apologies if this has already been discussed, but do the recommended gennies need a N-G plug to be safe?
http://noshockzone.org/generator-gro...utral-bonding/
D
DarrellT is offline   Reply With Quote
Old 08-14-2016, 12:31 PM   #2
2015 30' Classic
Pleasanton , California
To be safe from all hazards you would need to bond neutral to ground AND connect to an earth ground rod when operating the Honda/Yamaha generators independent from RV pedestals. I've never met anyone who actually does this. I think for the most part folks use the N-G plugs to satisfy complaining GFCI outlets.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 08-14-2016, 02:09 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Another thread on the same topic.
http://www.airforums.com/forums/f448/grounding-generators-155249.html
Old 08-14-2016, 03:12 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Don't think I have ever seen anyone ground a portable generator. Last time this same up I was dry camping in the Keys and surrounded by people (about 40 trailers) using generators. I made the rounds and saw no grounds being used.
MICHAEL
Old 08-14-2016, 05:45 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I spoke with a rep at Honda this week regarding this issue. I ask how to resolve the issues of (1) the plug in tester gives reversed polarity readings, and (2) the GFCIs do not functioning as they should. Mostly he avoided giving specific advice.
The only specific response I got from him was; "Honda does not recommend bonding the ground and neutral".
Alan
Old 08-14-2016, 06:30 PM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
In my post above, I also should have explained:
(1) I was asking specifically about my 2000 Honda generator
(2) I was asking about using a home made 120v drop cord end replacement plug with a jumper wire between the neutral and ground, if the generator would be harmed by using this plug.
(3) I was asking if the generator would be harmed when plugged in at my house where a neutral to ground bond is part of the electrical system (as required by NEC)
Mostly I got silence, and the occasional "ask your electrician".
Alan
Old 08-14-2016, 08:09 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The best answer I can give you is to contact a generator manufacturer like Generac who installs generators as backup power for homes.
IMHO. There is no difference whether it is a 2,000 watt or a 20KW Generator.
Old 08-14-2016, 09:33 PM   #8
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
No....you only need the N/G plug when using your genset for the AS to prevent a fault code on a circuit monitor or surge protector
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 08-14-2016, 09:44 PM   #9
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I have thought this through a lot, there is no good safety reason to either bond the "neutral" and ground or to drive a ground stake.
It might be beneficial however to connect the ground lug on the generator to the trailer frame, but I never have.
(I put neutral in quotes above because in this case, (unbonded), there really is not a neutral on inverter generators and some others)
Gradiens super tenui glacie.
Old 08-14-2016, 10:01 PM   #10
Al Boondy's Avatar
1973 31' Excella 500
Vicksburg , Mississippi
There is no difference concerning the size of the generator, but there is a big difference between a house and a travel trailer and between grid power and generator power.
Most bu generator transfer switches don't switch the neutral so ground rod isn't required. Some do switch neutral and rod is required. Some local codes require it either way. Some manufacturers require ground rod some do not. Legal reasons I suspect.
So the answer from Generac may be no while the answer from an inspector is yes while fed codes say sometimes.
I've never seen an install without one for 15 bucks it worth it just to keep inspectors happy.
Al Boondy is offline   Reply With Quote
Old 08-14-2016, 10:36 PM   #11
Al Boondy's Avatar
Ditto and I'll go one better.
If the trailer happens to be incorrectly wired (line and neutral switched at plug and neutral and ground bonded in sub panel) touching the skin could shock you IF generator was grounded but there would be no path to ground thru you if it wasn't.
Pushing it but any excuse to do less work while camping works for me. :-)
Old 08-15-2016, 05:38 AM   #12
Wink
EXCEPT....if I want to use a circuit monitor while on my 2000i, w/o the n/g plug you WILL get a ground fault code....
PFC
RLC
Old 08-15-2016, 08:11 AM   #13
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Using my Honda 2000, I know power is at all of the receptacles and all of the appliances will work when plugged in.
But, the GFCI's in my trailer, when tested, will not trip in ground fault condition while the trailer is connected to the generator with a floating neutral. The kitchen, bath, and outdoor GFCIs do not function as they should.
The issue that concerns me is SAFETY.
When those GFCIs are not working properly; What can happen if the electric coffee pot falls into the sink while you are washing dishes? What can happen if the hair dryer gets dropped onto the wet rug you are standing on? What happen when using an electric tool while it is wet where you are standing?
And another concern; If one chooses to use the home made ground/neutral grounding bonding plug, can the generator frame become energized, since the neutral does carry voltage. The generator has no ground rod, but the trailer is setting with the jacks down. In this condition could someone touching the generator get shocked, while it is running and connected to the trailer?
Alan
Old 08-15-2016, 08:29 AM   #14
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
In grid connected systems like residential power the hot line has 120 volts with respect to neutral which is bonded to ground and a ground rod. So the potential from hot line to earth ground is 120 volts. With a trailer which has no connection between neutral and ground, no connection to shore power, and operating fron a generator which is not grounded, there is no reference to ground and no risk of shock. But if somehow the generator gets referenced to earth ground this may no longer be true. The safest approach is to ground the generator and the shell of the trailer. This is typically a requirement in military equipment shelter specifications but I have not seen it done with RVs.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Odd electrical ground / neutral issue on '89 370 classic romakdaddy Classic Motorhomes 29 10-23-2013 05:44 PM
Neutral Ground Fault on ciruit 1 ViewRVs Argosy Motorhomes 10 06-05-2013 07:31 PM
Hot Ground/Neutral Reversed Snaken49 Electrical - Systems, Generators, Batteries & Solar 14 08-23-2009 03:27 PM
Honda EU2000 x 2 vs Honda EU3000 and Yamaha 3000 IntegrityAir Generators & Solar Power 43 07-01-2009 11:19 AM
