Old 08-15-2016, 10:10 AM   #15
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
The thing about using an unbonded inverter generator is that the earth/neutral is the thing that makes much of the shock hazard.
For example, the "energized shell" that we often hear about is almost an impossibility with an unbonded generator.
Since the shell of the trailer and all within the trailer is not energized, much of the reason for employing GFI circuits is not in play.
In other words, with the shell of the trailer not effectively providing half of the circuit, the chance of electrocution is drastically reduced from the get go.
That said, dropping a blow dryer in a sink or tub full of water while a body part is in the water would be an exception where GFI would provide a serious advantage.
Gradiens super tenui glacie.
Old 08-15-2016, 10:46 AM   #16
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
What has happened to us that we need a generator to power a hair dryer, while boondocking?
Larry
lsbrodsky is offline   Reply With Quote
Old 08-15-2016, 11:36 AM   #17
Al Boondy's Avatar
1973 31' Excella 500
Vicksburg , Mississippi
Larry
Got married?
Al Boondy is offline   Reply With Quote
Old 08-15-2016, 11:57 AM   #18
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Different people, different uses and expectations.....
I have been "boondocking" at my place of work for about the last 100 days. My wife expects to use her blow dryer....
(We are plugged into electric)
Old 08-15-2016, 12:43 PM   #19
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I'm no electrician but I've done a lot of reading on the topic and I while I have done a lot of reading by what looks like qualifed spokesmen, I'm still a little uneasy with this concept.
In my simplistic mind I see some repetitive statements.
First some surge equipment and GFI outlets will fail to work correctly in an RV if you use a portable generator and do not have a neutral/ground jumpered plug.
Second, grounding rods are unreliable means of grounding a portable generator.
Thirdly if you are using a portable generator as auxiliary power in a home with the generator running through a transfer switch, the ground will be supplied by the grounding bus within the home's power box. In that case you should not use a neutral/ground plug in the portable generator. I assume in this case that the home has proper wiring with grounded outlets and that the devices you use have grounded plugs.
I feel comfortable with the third paragraph regarding the use of the generator at home with a transfer switch. The other two items, I'm still not comfortable with.
My backyard neighbor is a retired electrician. I'm going to have a sit down with him and see if he can clear this info with me.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-15-2016, 02:39 PM   #20
Tn Traveler's Avatar
2006 25' Safari
Signal Mountain , Tennessee
I am not an electrician. I do have a 12 KW diesel generator on my boat. I asked an ABYC Certified marine electrician about the grounding. He said there was no need to ground it. The neutral and ground are bonded inside the generator. What the electrical theory behind that is I do not know, but it works.
Don
'06 Safari 25 LS
'97 Chevy Suburban K2500 Diesel
TN, Greenest State in the Land of the Free
" America is not a place;it is a road." Mark Twain
Tn Traveler is offline   Reply With Quote
Old 08-15-2016, 02:41 PM   #21
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
This simple illustration might help.
When the system is bonded, if a person touches the body of an Airstream (or anything conductive connected to it) and the black wire anywhere, a person will get shocked.
If running an unbonded generator, touching the shell of the Airstream and the black wire, this will NOT cause a shock, assuming that the trailer electric system is otherwise wired correctly.
Old 08-15-2016, 02:50 PM   #22
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I am thinking that if electrical engineers had it to do over again with a strict "safety first" mindset, our power grid would not be designed with the neutral leg tied to an earth ground.
I think that was a compromise to the cost of copper right from the get go.
Odd electrical ground / neutral issue on '89 370 classic romakdaddy Classic Motorhomes 29 10-23-2013 06:44 PM
Neutral Ground Fault on ciruit 1 ViewRVs Argosy Motorhomes 10 06-05-2013 08:31 PM
Hot Ground/Neutral Reversed Snaken49 Electrical - Systems, Generators, Batteries & Solar 14 08-23-2009 04:27 PM
Honda EU2000 x 2 vs Honda EU3000 and Yamaha 3000 IntegrityAir Generators & Solar Power 43 07-01-2009 12:19 PM
